Question about Dell Studio Xps 9100 Desktop Computer
Computer won't turn on.
It won't turn on. All cord have been checked.
  • 516 Answers
There must be a problem with your power switch on your computer casing, or motherboard or power supply.
Detach your power supply and try this, to check if your power supply really works. If the auxiliary fan will turn, your power supply is good
Computer won't turn on. - 25627818-lfqggqo5gl3n2v4xynrvsb5u-5-0.jpg Testing your power supply and motherboard as seen on photo
If the cpu cooling fan and power supply did not turn the fan, but you have checked already the power supply that is working then you can conclude that your motherboard is need to be replace. But the power supply and motherboard and working, meaning to say your computer casing need to be replace or try fixing the contact of the switches attach to your casing.
Have a good day.
Posted on Apr 05, 2015
Computer won't turn on help!!!!
Unplug, remove the battery, plug in, try to turn on. If that fails, try another AC/DC cord/charger with the EXACT same power specs. Has the AC jack been damaged due to pulling on the cord? Damage due to Power surges? Do you leave it plugged in while not in use a lot?
Apr 13, 2013 | Computers & Internet
Dell latitude won't charge
The internal battery may need replacement, especially if you have had this Notebook for several years
Mar 22, 2013 | Dell Latitude D600 Notebook
Laptop has power but won't boot up
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the acer power adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC adapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Feb 13, 2013 | Acer Aspire One PC Notebook
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Pixma ip1600 won't turn on. No power cord just a cord from printer to computer. I unpluged the entire system and waited 15 minutes and it still won't power up. Any suggestions?
You need the power cord which has a polarized plug on one end. The other end (a figure 8 like shape) will fit into the printer. See http://gdlp01.c-wss.com/gds/7/0900005347/01/ip1600esi_us.pdf . Amazon and other sites have replacement power cords for Canon inkjets and inkjet multifunction printers. One source: http://www.amazon.com/Canon-ip1600-ip6600d-ip6700d-Printer/dp/B003XT2LKC .
I hope this helps.
Apr 05, 2012 | Canon PIXMA iP1600 Printer
It won 't turn on
check your power cords, check your outlets, check your surge protector, check the switch on the back of the pc. there may be a black toggle switch with a circle and a line, make sure it's flipped to the line side. if all that is normal, unplug the cord from the computer and open up the case. look at all your power plugs and make sure they're all secure, try and reseat the 1 or 2 main plugs, there should be a rectangular 12 pin plug and maybe a 4 pin plug. unplug them and then plug them back in. put the case back together plug it in, and give it a go. if still nothing then you have to troubleshoot whether the power supply is junk or if your motherboard died. we'll move on to that if it comes up. good luck!
Jan 30, 2012 | Gateway 300 X PC Desktop
The computer won't turn on
You could be having any of several problems.
First double check to make sure no cords came loose - you may even want to unplug and replug the power cable both out of the computer and the wall.
If you do not have a loose cord, listen closely when you attempt to turn the computer on - is it making any noise? Do any lights come on? If not, you likely have a bad power supply.
If the computer does come to life, just no reaction on the screen, make sure your monitor is plugged in and turned on, and try unplugging and replugging the cord connecting the computer and the monitor.
If this still does not get it, you may be dealing with either a graphics card or monitor problem. If you have an alternate plug for the monitor to go - try that, or if you have a different monitor to use, try that.
This should either greatly narrow down or fix the problem for you.
Aug 24, 2011 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
My compaq presario cq60 won,t turn on. the power light next to the charger cable is on but it won,t turn on
The charger is functioning well. There are still two possible reasons why your computer is not turning on. 1. The battery, 2. The computer itself.
What you need to do is to isolate the problem.
Here's what you can do to isolate the problem.
1. Remove the battery from the computer.
2. Turn on the computer using the cord. Remember not to put back the battery yet. Just the cable and the computer connected. If the computer turns on, then, you need to replace the battery.
3. If it still not turning on by using the cord alone. Try to wiggle the cord to check whether it's loose or not. Check if there are some signs of power on the computer. If there is a power like lights lit in the computer, then, it's the computer that's having the problem. You need to bring it to a technician if that's the situation.
Please let me know if there are any development after doing the troubleshooting above so that I can get back to you if you need my help.
Thank you for using fixya.com
CARLO
Apr 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Dell Studio Xps 9100 Desktop Computer Logo
138 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
