Question about Maytag Kitchen Ranges
Gas owen overcooks - Maytag Kitchen Ranges
    Master:
  • 481 Answers
On the dial for temp setting for the oven, there may be an adjuster for the temperature. Pull the knob off and see in the stem if there is an adjusting screw, a tiny screw driver would turn the slot of the screw. With a candy thermometer or equivalent, set the oven temp dial to a point and compare the temp setting with the thermometer. Adjust the screw as necessary.
Posted on Apr 07, 2015
    Champion:
  • Maytag Expert
  • 220 Answers
I get this service call a lot so lets verify temp before we discuss possible causes set the rack in the middle of the oven hang an oven thermometer in the center of rack set a 350 let run 1 hour check the temp after an hour this gives the oven enough time to cycle and stabilize this will give you the true average of oven, temp placement of thermometer is important plus or minus 15F on either side of 350 is not that much of a big deal the max range for a temperature offset is usually 30F, there should be a tech sheet in a plastic pouch on the back of the unit now if you do find it to be running 50F too hot well there are test to determine if the temperature sensor is operating correctly it should read appx. 1654 ohms at 350 this tells the control board to open the heat relay stopping power to the gas valve lot of work you have to have the oven out back panel off to access the wiring going to control unplug machine at 350 disconnect wiring from board to ohm out sensor, sensors go bad and so do boards, sensor is cheaper try changing it first.
Posted on Apr 04, 2015
Testimonial: "Thanks for your answer. I already had changed the sensor, but did not help. Stove is already 10 years old, I think I dump it."
Address for Owen Trevor Evans.
There are 387 Owen Trevor Evans in all the countries of the world. He sound a bit Welsh, but you need to narrow it down a bit.
Go to the BT website and put his name in with the rough location.
Google leads me to this photograph
1978 Gwyr Ambiwlans yn derbyn rhodd Ambulance personel receiving donated...
Owen Evans leads me to here, and a lot more hits.
Owen Evans Google Search
Feb 02, 2018 | Computers & Internet
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
Poor quality bread -- overcooked, under-risen bricks
Here's the manual...you may want to review how you are making your bread (have you recently changed any of the ingredients?):
http://www.kenwoodworld.com/uk/products/cooking-baking/breadmakers/bm260-bread-maker-0wbm260001?TabSegment=support
Nov 17, 2017 | Kenwood Kitchen Appliances - Others
How do i light a gas pilot on a new GE gas range model no. s&d ser ha211504p,ref 18 no owener manuel
Go to a seller of the product or download instructions from the maker's web site.
Oct 05, 2014 | Kitchen Ranges
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
How do you check oil in pump on Dewalt DPD3100 pressure washer
There is a little window on the side of the pump to see the oil level but thats normaly the problem None of these companys make there owen pumps or engines i owen serveral power washers if you can tell me more about the problem Iwill likely know how to fix it see who made the pump and the engine and let me know pier_j
Nov 23, 2010 | Dewalt DPD3100 Gas Pressure Washer
Summit electric range overcooks bottom of baked goods
have it calibrated or get oven thermometer and figure differential yourself, say it runs 30 degrees hot etc
Aug 23, 2009 | Summit Appliances Division Professional...
Oven gets too hot
Thermostat needs to be replaced.
Apr 10, 2008 | Ovens
Whirlpool gas range
sounds like you have 2 problems the first the oven wont light is either a ignitor issue or a gas valve problem even though the ign. glows it may not be drawing enough amps to open the valve.it should be 3.5-5.2 amps at full glow.. have checked that? the over cooking sounds like a thermostat issue.not a lighting issue
Feb 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
82 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
