Question about Keurig 2.0 K550 Brewing System
Touch screen is blank - Keurig 2.0 K550 Brewing System
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Phone screen completely black
Is it a touch screen? Has it been dropped at all? If so, the internal screen could be busted. Sometimes the touch part will still work itll just be a blank screen though. You may need to order a new internal lcd screen.
Dec 04, 2012 | Motorola Mobility Triumph
Touch screen on acer z290 goes blank after 2 seconds
mine after few second turns off.
cpu remains cod and fan is working and nothing getting hot on matherboard.
Feb 23, 2012 | Acer Veriton Z290G 185 320GB
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
Screen is blank on my Alpine IVA-D106 and menus, video etc only appear when I touch the screen. A few seconds after touching the display goes blank again.
check the screen configuration using the visual button on the top right side of the screen, you should disable the "OFF" button
Apr 16, 2010 | Alpine IVA-D106 Car DVD Player
Blank ipod touch srceen wont respond
press the home and sleep button go to this video and see it
http://www.youtube.com/watch?v=JnqdRmRaFKQ&feature=related
Oct 19, 2009 | Apple iPod touch
HTC Touch HD Screen Blank out during call.
Hiya,
This is a setting designed by HTC to stop inadvertently pressing keys with your face when you are on the phone, but yes it is very frustrating at times. I've found that the easiest way to get around this is:
When you make a call, as soon as you've pressed 'dial' press the 'kepad' option in the lower left of the screen, this will stop the screen going blank.
I've not had any luck changing the setting within the phone so this is just what I do to resolve it. To be honest, the only time I really need the screen to be on is when I'm using the keypad to type in numbers for automated services anyway lol.
Hope that helps some of you out?
Ads
Apr 10, 2009 | HTC Touch HD Smartphone
LCD Blank
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
May 02, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Keurig 2.0 K550 Brewing System Logo
285 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
