FixYa.com
Tags:
GE AHG40LJ Dehumidifier
GE AHH40LH DEHUMIDIFIER (by 2 users)
posted by TIMWIM on Nov 14, 2007
DEHUMIDIFIER FREESE UP SOLID ON THE BACK. THE COIL AND FILTER ARE CLEAN. IS IT A BACK AUTO DEFROST THEMASTAT, IF SO WHAT IS THE PART NUMBER NEEDED.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by j bagger, posted on May 07, 2008
Hello--the unit is two years old. Works like a charm up until about 2 weeks ago. All of a sudden it starts to freeze up on the rear of the unit. I removed the filter from the rear and everything looks good with the coils/grill? I raised the unit up off the floor to where the temp. may be a little warmer, still icing up. Machine is in a basement that stays around 60 degrees F but has worked without any problems for 2 years. Any suggestions?
Best Solution
posted on Nov 16, 2007
Helpful (85)
fridgetech
Rank:Guru Guru
Rating: 88%, 692 votes
Either the humidistat is bad and not letting the unit cycle off, there isn't enough humidity in the air, or the condensor coils are too dirty.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dehumidifiers problems?
ice forma on back of unit
ice forms on back of unit Answer This...
I have a GE Dehumidifier,
I have a GE Dehumidifier, Model... Answer This...
dehumidifier GE
after 10 to 15 minutes of... Answer This...
dehumidifier freezes up
mornin. each time i attempt to... Answer This...
fan shutting down
I Just bought a dehumidifier... Answer This...
Repair Service
Find Dehumidifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
