Question about Samsung Video Cameras
Samsung SC-D453 Camcorder. Getting a mechanical fault message r and it is running on AC power. I get the message with a recorded tape as well a s a brand new tape.
  • 19 Answers
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Posted on Dec 21, 2007
  • 848 Answers
SOURCE: samsung vp d20 camcorder
MiniDV cameras have two video heads on the rotating drum, which read and write the picture in broad horizontal bands. When one head is not working, normally because it is clogged by dust/dirt/tape residue, you see broad bands of noise across the image occupying exactly half the total image area.......
Posted on Aug 22, 2008
charcois
  • 763 Answers
SOURCE: Sc-D453 dosn't connect to my computer
you need a driver for that to be able to recognize your camcorder on your computer.
http://www.samsung.com/us/support/download/supportDown.do?group=camerascamcorders&type=camcorders&subtype=minidv&model_nm=SCD453&language=&cate_type=all&dType=D&mType=UM&vType=R&prd_ia_cd=04020100&disp_nm=SCD453
after you download the driver, install it to your pc and it should be recognizable after you done it.
as for editing, windows moviemaker is a good software for editing but i prefer to use Ulead Movie maker, Ulead Producer or anything about Ulead because its so easy to use for editing and saving a movie or video files from your camcorder. you can also use your usb for connecting the interface with your camcorder and pc. hope that helps you and thank you for using fixya. dont forget to rate thanks!
CHARCOIS
Posted on Oct 17, 2008
SOURCE: Samsung camcorder disc error
okay so i have founnd the solution happily and i am actually finalizing my disk right now!!! woooohoo plug the camera in and use the remote that it came with to navigate through the menu!! the finalize button is now able to function!! I hope this works for u!!
Posted on Mar 11, 2009
SOURCE: Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Posted on Jun 08, 2009
Dear Fixya, I'm problem with my mini-tape dv rollout or spitting out while loading on Samsung camcorder SC-D453 any solution?
sir,
Please use a contact cleaner spry,
eject the mechanism, take the cassette out, look at the left below side of the eject mechanism, you can see the mode selector switch lays there. (may be not clearly visible) just point the nozzle of the contact cleaner spry to that direction spray a little, then let it dry for a while, connect the power, on it, put the cassette in and ply it.
this will cure most of the similar problems.
Jan 20, 2016 | Samsung Video Cameras
Rejecting tapes
I had the same problem with my SC-D363. My screen would flash "D" and tell me to eject the tape.
Here is the SOLUTION:
1) Very Gently unscrew (4 screws)and remove the front casing portion of the camcorder, be sure not to strip the screws.
2) Directly underneath the lens there is crosslike metal support that extends from the tape
compartment chassis. The green circuit board should rest on top of it as shown below instead of
underneath it, as it was when it was assembled.
And Voila! Camera works like when it first came out of the box.
Custom Car Parts
Jun 06, 2012 | Samsung SC-D453 Mini DV Digital Camcorder
When we record we have a clear view and it appears there is no problem, however on any playback we have horizontal lines across the screen. I have checked to make sure that it isn't the tape that is...
Hi:
Try cleaning the video heads, this is a indication that the video heads may be clogged and needs cleaning, If you have not kept the heads clean during use, or for extended amount of time, you may need a professional cleaning, try a tape cleaning cartridge first if this does not unclog the heads then take it in for service.
Jul 08, 2011 | Samsung SC-D453 Mini DV Digital Camcorder
I have a Samsung camcorder and when I play mini dv tape recordings from Canon camera I recorded on , the sound is distorted
If the tape plays correctly in the Canon camcorder, here are a couple of possible reasons for the issues you are having:
1. the Samsung camcorder has a cleaning issue - try running a dry head cleaning tape for about 5 to 10 seconds and see if that helps.
2. The alignment is off between the two different camcorders. Nothing you personally can do about that, but a repair center would be able to correctly align the tape path on both camcorders.
Do the tapes that you record on the Samsung have issues when you play them back on the Samsung? If so, you have a problem with that camcorder (may be cleaning, but could be a mechanism problem) Hope this has helped you. www.austintelstarservices.com
Aug 30, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
CHARCOIS
Oct 17, 2008 | Samsung SC-D453 Mini DV Digital Camcorder
Camcorder keeps shutting off when plugged in - how to disable power saver?
slinkystairs,
Simply remove the tape from the camcorder, and it should stay on. If you have a tape in the camera, the auto-shutoff is activated assuming you wish to record to the tape, regardless of the firewire connection to your PC.
Dec 29, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Video Cameras Logo
42 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
