Question about Hardware & Accessories
Setting a dawn/dusk timer for the Utilitec 0192773.
I have followed the instructions. The time is set. When I try to program the timer and I select the time, it NEVER cycles to the the sun/moon symbol. I am only able to code in a specific time! When I set it mode to the sun/moon symbol it does not do anything at the selected dawn/dusk times. I have another dawn dusk switch and it works in a similar fashion, but I had no issues setting it to work. Is there a piece I am missing? I have already referenced this document which I have seen posted many times http://waterheatertimer.org/Program-wire-Utilitec-0192773.html. The only time I can get the lights to automatically go on and off is if I hard code in a timed program. But the point was to be able to just say dawn to dusk.
    Top Expert:
  • Hardware & A... Master
  • 44,062 Answers
You may have to repeatedly advance the hour setting to get it to change from AM to PM.
Posted on Mar 25, 2017
SOURCE: I have a utilitech 0192773 self adjusting timer
Do not go to Utilitech.com; it's a different company. It's actually at place called TheNCC and is in tiny, tiny print at the bottom of the instructions.
Instead, go to:
http://thencc.com/ncc/support_results.asp?criteria=192773&Submit=Go&SearchRun=RunGo
You should find a PDF for the product and then zoom in to be able to read the instructions. I was not able to read instructions that came in packaging.
Posted on Feb 25, 2010
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
Here is the url to the pdf file. You can then magnify your computer screen.
http://www.thencc.com/LS/Instruction/LW60418_Instruction.pdf
Posted on May 14, 2010
SOURCE: how to program the STO1C timer for on time and off
Yes the ST01C manual is confusing at the exact point you are stuck at.
Open following page to see step by step plus illustrations that show the confusing part of manual:
http://waterheatertimer.org/ST01C-program.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 07, 2011
SOURCE: i am programming my sto1 and I cannot get to dusk
ST01C instructions are confusing, and are longer than space allowed for free answer.
Open following link for re-written instructions that might be clearer, with illustrations how the display should look.
http://waterheatertimer.org/ST01C-program.html#astro
To clear the timer, hold down on-off button and press reset button.
Release reset button and keep holding down on-off until INIT displays.
If you go through re-written instructions and get confused, add a comment with exact step where it is confusing and I'll pull out the ST01C I use for testing and maybe I can find what is causing the problem.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Posted on Apr 03, 2011
  • 5245 Answers
SOURCE: I have a Intermatic self-adjusting wall switch timer and I can't program it even though I have followed the instructions 3 times.
Program 1 is ON, and program 2 is OFF, 3 is ON, and 4 is OFF, etc
Copy following link for EZ step-by-step programming for ST01C timer:
Posted on Jul 01, 2012
Unable to Program Utilitec 0192773 Timer
Let's figure it out together. I have one of these timers for testing, and can hook it up if needed. Add a comment as needed.
PLEASE read following material, so we are both saying the same thing.
There are two different options for programming.
7-day programming, and dawn-dusk programming.
You choose one or the other
This might be the point of confusion.
Copy following link for larger print instructions.
DST is daylight savings time, and you can choose to have automatic DST adjustment twice per calendar year, or choose not to have DST
Be sure to RESET timer before programming. This will clear any programming glitches.
Make sure that each ON time has an OFF time.
So Program 1 ON is set for day(s), hour, minute
The Program 1 OFF is set for same day(s), hour, minute.
Make sure there are no conflicts between day(s).
If selected time is 12:00, then use 11:59 to avoid am-pm conflicts.
Oct 08, 2012 | Hardware & Accessories
Utilitech #0192773 setting the timer for not working
I do not have repair for defective timer.
Open following link for clear large-print instructions.
Add a comment about part of manual that does not work, for possible additional help.
1) Timer replaces single-pole light switch only.
2) Timer does not have a battery and must be wired correctly before programming can take place.
3) Choose either dawn-dusk or programmable on-off:
Timer can be set for dawn-dusk operation
-OR-
Timer can be set with 7-day on-off functions of your choice
Aug 18, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Bought a Utilitech #0192773 to replace an older and non-working Intermatic SS7 series. The Intermatic had a black wire connected to hot, and a blue wire connected to neutral, and a red wire was capped off...
Utilitec 0192773 replaces single-pole switch and will not work for 3-way applications.
Open following link for clear wiring and programming steps for Utilitec 0192773
Utilitec can also be tricky to program if you are setting up astro dawn-dusk function.
For others finding this thread, same wiring applies to in-wall programmable timers by GE, Woods, Swilight, Sylvania, Tork, Hagar, UPM, Leviton, Grasslin, Wattstopper, Westek, and Intermatic analog timers. Intermatic battery-operated, Brinks and Aube timers are wired differently since they also work for 3-way applications.
Jun 05, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Does timer 15071 automatically adjust for changing daylight length in addition to adjusting for daylight savings time?
GE 15071 sold at Home Depot and on-line has feature that adjusts for daylight savings time.
GE 15086 does not offer automatic adjustment for DST
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Daylight savings time (DST) is not same as dawn-to-dusk astronomical timer.
GE 15071 and 15086 single-pole timers do not have dawn to dusk astronomical feature.
For single-pole dusk-dawn astronomical with DST, Lowes sells Utilitec-0192773
For 3-way switching, 7-day DST -or- dawn-dusk astronomical:
http://waterheatertimer.org/Aube-timers.html
Apr 17, 2011 | GE Hardware & Accessories
Is it possible to set this model(LW60418), for turn on/off at sunset /sunrise? Ron, Weymouth, Ma.
No, Utilitec LW60418 timer is not made for astronomic dusk-to-dawn operation.
However Utilitec LW60419 / 0192773 is made for astronomic operation.
Following link shows timer, manual, and wiring instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Dec 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
Utilitec 0192773 with 7-day and astro dusk to dawn
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
The light does not stay on until sunrise. This is just since the clocks went back on the 8th November,.
You posted under ST01C.
It sounds like your timer is not set to automatically adjust for DST.
Open following page to see step by step for setting DST to automatic so timer auto-adjusts for DST:
Steps are shown under 'setting current time'
Utilitec 0192773 also has dawn-to-dusk timer with DST option.
See those instructions:
Nov 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set utilitech wall timer for dusk/dawn settings
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have been trying to program my utilitech timer that controlls my front door lights. I have been able to program monday only. I did the same program for the other days but at dust the light will not come...
1) I am going to guess you have the Utilitec 0192773 in-wall timer that replaces a switch
I say this because you are controlling outdoor lights -and- because you have the dusk-to-dawn feature.
2) Short answer: I think you have selected your days incorrectly when programming timer
To review your programs:
Press PROG button once and program1 ON displays
Press PROG again and program1 OFF displays
Press PROG third time, program2 ON displays >> a fourth time progrom2 OFF displays
And so on..
3) I suggest you write out a schedule of your times
Press PROG button and then press TIME button to see your programming: Review the days carefully, review if you have sunrise-sunset selected for each program. You can change the setting while going by using the +- button.
4) As a general rule, programmable timers do not 'operate as expected' if there is a conflicting program. For example program1 says on at 7 and off at 8, and program2 says the opposite.
Suggested solution is make a chart of your settings before programming.
5) Long answer: write out the manual instructions that seem unclear to you
6) To reset everything and start over, push & hold reset button with a paperclip.
Here I am testing the Utilitec timers for wiring and programming difficulties
Oct 21, 2010 | Intermatic & Self-Adjusting Wall Switch...
Utilitech Self-Adjusting Wall Timer- #0192773. Unable to program timer. The instructions are so small it is hard to read them
Utilitec 0192773 is also listed as LW60419
1) Has optional daylight savings plus dawn to dusk programming
2) Electrical wiring must be connected in order to program timer. This is because timer is powered by electric circuit (instead of battery).
3) Program choices:
-Individual days MO TU WE etc
-All 7 days of week
-Weekdays
-Weekends
4) Large manual + wiring tips:images load slow with dial-up
5) Enlarged manual
-Click on image to enlarge
-For more size, hold down Ctrl key on keyboard and use scroll-wheel on mouse
Sep 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
820 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
