Question about Garden
Lawn mower will run with gas poured into carburetor, but will not start when pulled
  • Garden Master
  • 2,540 Answers
Take the fuel bowl off and clean it out and clean the fuel jet which quite often is the bolt that holds the fuel bowl on. I use an air compressor to do this but some times you can blow it out other ways. Sometimes a small fine wire can be used to clean those small holes. A plugged fuel jet will not let the engine run properly.
Posted on Apr 05, 2015
4 Suggested Answers
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
  • 691 Answers
SOURCE: Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Posted on Sep 01, 2009
Testimonial: "This guy really knows what he is talking about. I would highly recommend him."
kel1guy2002
  • 3740 Answers
SOURCE: 190cc series 675 lawn mower wont start..pour gas
Hi and welcome to FixYa. I am Kelly
Just by searching I think this is your engine number:
126T02-1045-B1
This should be your parts manual: (3.01 Mb)
http://www.briggsandstratton.com/document/index.aspx?doc=MS3728_G_LO.pdf
Most likely the main fuel jet orifice that is inside the threaded area of the Fuel float bowl nut has debris in the pin-hole of the orifice.
Remove the Fuel float bowl and spray carb cleaner using the spray tube directly into the center of the bowl nut area to remove the debris from the main fuel jet orifice. Clean the Fuel float bowl and the bowl nut. On this unit the bowl nut acts as the main fuel jet so any debris in the bowl nut will restrict fuel to the engine. See items 117, 118 and 236 on page 3 of the manual above for location.
Additionaly make sure the fuel shut off on the bottom of the fuel tank is working properly Remove the output hose and check for feul flow. (item 958 bottom right page 3 of the above link)
I think once you clean the float bow bowl and nut that it should work properly. If your still having problems I need to know if this has a primer bulb, Choke Lever or is an Auto Choke carb.
Thanks for choosing FixYa,
Kelly
Posted on Aug 20, 2011
Briggs and stratton 650 series mower starts but cuts off Replace spark plug and put oil in It is a self propelled mower
be sure the oil level is not over the full mark. the plug is good? try to pour some gas in the carburetor, if it starts and runs a few seconds i would say the carburetor if plugged and needs taken apart and cleaned real good
Aug 13, 2016 | Garden
Troy-bilt mower will not start. If I put gas directly in carburetor it will start but appears to not be getting fuel.
Darlene, if it will start with gas poured in the carburetor. it is fuel relater. take the carburetor off clean it real good and it should run as good as new.
Jun 03, 2016 | Garden
I have a murray 6.5 quantum 22inch blade mower that is a couple years old but was only used a couple times last year. It has oil, it's getting spark but it isnt getting fuel. I removed the air filter and...
Remove the old fuel from the tank. Change the gas filter if there is one. Get a can of spray carburetor cleaner and a can/bottle of fuel line cleaner. Spray carburetor cleaner in the carburetor where you put the gas ( remove the air cleaner) . Pour the fuel line cleaner in the gas tank with fresh gas and try to start the mower. Spary some carbuerator cleaner in the carburetor and try to start the mower a few times.
Jun 12, 2014 | Garden
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 | Garden
MmThe lawn mower will start, but it will cut off. My Husband says that it is not getting the gas properly. It is an old lawn mower and has not been used for some time. I hope you can help us.
If the mower has a fuel filter, replace it with a new one first thing. You can also try this and it may or may not help if the engine will start and run for a few seconds. Purchase a can of Seafoam Engine Treatment at Walmart and most auto parts stores. Remove all old fuel from the mower and pour in fresh fuel. Pour in 4 ounces of Seafoam and start the engine. If this does not help you will need to remove the carburetor and have it cleaned.
Jun 11, 2011 | Garden
Bought this lawn mower.It was sitting for two years and now it won't start.
first things first:
1) make sure that the kill for the magneto/coil is breaking contact( it is on the side of the mower,follow the cable down from the red bar)
2) gas to carburetor
3) spark to plug/s
4) gas to cylinder/s
pull plug and try starting mower, observe spark plug for spark and fuel coming out of cylinder/s. if spark no gas, then check to see if it getting to the carburetor, if it is then it is the float and seat in the carburetor and will need to be cleaned/replaced/rebuilt. Or just simple pour gas into the carburetor and try starting if it starts then it is the fuel line, carburetor. Hope this helped Tim
May 22, 2011 | Garden
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
My mower is a Yard machine with a briggs and straton engine self propelled it will start but only run for a second its like it is not receiving gas any answers
pull the fuel line off of the carburetor, if gas pours out freely the shut off valve and filter are ok. If not replace the fuel filter or make sure the shut off valve is open. If the fuel flows freely then its the float valve in the bowl that is clogged/stuck or there is something in the bowl plugging the main jet.
Aug 26, 2009 | Garden
How do you get to the carburetor in a Yard Man
Take off the air cleaner an pour in a tablespoon of gas, if it runs for a couple seconds, then you have a carburetor problem. If not, maybe spark plug problem.
Apr 05, 2009 | Garden
Lawn mower won't run
make sure the tank has fuel and replace the fuel filter
Jul 20, 2008 | Electrical Supplies
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
