Question about Arctic Cat 2007 Bearcat 660 Turbo WideTrack Articulating Rail
How to remove primary clutch - Arctic Cat 2007 Bearcat 660 Turbo WideTrack Articulating Rail
  • 25 Answers
In the center of the clutch there's a hole with a bolt a ways in usually 12mm or 1/2 inch 16 point socket on a long exstention find the right size then use a wooden handle of hammer or something to put throw the clutch to hold it from turning when taking the bolt out after that you need the proper puller to take the clutch off leave hammer in turn in puller tell nice and tight if it hasn't already popped off hit the end of the puller with a hammer 4-5 times if not off tighien it some more and repeat it will come with some more hits on the puller when its good and tight good luck
Posted on Oct 26, 2015
I know where to add the oil and transmission fluid but how do i drain and add my primary chain fluid
On the underside of the primary all the way to the rear of the primary just under the clutch area is a pipe plug. Remove the plug to drain the oil. To refill the primary, remove the round derby cover from the primary over the clutch. Stand the bike straight up and fill the primary with 20W50 engine oil until the level just comes to the bottom of the clutch drum. Do not overfill or the clutch will drag.
Good Luck
Steve
Aug 03, 2011 | 2000 Harley Davidson FXST Softail Standard
Removal motorsprocket
I'm going to assume that you are talking about how to remove the engine sprocket from the sprocket shaft in the primary cover.
First, disconnect the battery and drain the primary. Look underneath the primary and loosen the locknut for the primary chain adjuster and loosen the primary chain by turning the screw outwards a few turns.
Then take the derby cover off the primary and remove the spring and locknut for the clutch adjustment. Remove the screws from around the primary and break it loose from the engine. Turn the clutch adjustment screw clockwise while removing the primary cover. Lay the primary cover aside.
Now, there is a plate in the center of the clutch assembly held in with a circlip. Remove the circlip. Now you'll need either an air wrench or a locking bar to lock the primary to prevent it from turning so you can get the clutch hub nut and the engine sprocket nut off. The engine nut has right hand threads and comes off normally. The clutch hub nut has LEFT HANDED THREADS and you must turn it in reverse. Once you get the two nuts off, you can usually grab the engine sprocket and the clutch assembly and lift those two units and the chain off at once. Sometimes you may need a puller to get the engine sprocket off but usually it just comes right off.
Installation is the reverse with the engine nut being torques to 150 foot pounds and the clutch hub nut torqued to 60 foot pounds left handed.
Good Luck
Steve
Mar 03, 2011 | 2000 Harley Davidson XL Sportster 883
How do i change my clutch and plates
Harley changed their clutch in 1998 and I don't think they've changed it since. To change the plates in your clutch:
First, disconnect your battery, Remove the floorboard on the primary side and drain the oil out of the primary. Remove the outer primary cover. Remove the six screws in the clutch assembly and remove the clutch plates and steel plates. Soak your new clutch plates in oil overnight. Replace the old parts with the new parts in the exact same order. Rinstall the bolts using Loctite 242 (medium strength blue) and torque the bolts to about 20 foot pounds. Adjust the clutch according to factory specs and reinstall the outer primary cover. Add oil and reconnect the battery. Put the floor board back on and you're ready to ride.
Ride Safe.
Steve
Jan 03, 2011 | 2008 Harley Davidson FLHX Street Glide
Removing primary cover on 04 1200c
To remove the primary cover from you Sporty, you'll have to remove the shifter and foot peg. Then loosen the locknut for the primary chain adjuster and turn the adjuster downwards to loosen the primary chain. Then remove the plug at the bottom rear of the plug to drain the oil from the primary. Remove the clutch release mechanism cover from the outer primary. Remove the spring and locknut. Turn the clutch adjuster screw as far clockwise as you can turn it. Then remove all the bolts around the outside of the cover. While pulling the outer cover gently away from the engine, turn the clutch adjuster screw clockwise until the cover comes off.
Good Luck
Steve
Dec 18, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
Removal and installation of 1988 harley sportster clutch
In order to remove the clutch from your bike, you must have a special tool. You'll need H-D #34761 in order to remove the snap ring holding the clutch together.
Disconnect the battery, drain the primary, and remove the primary cover. Once you have the primary cover off, you can remove the nut from the compensator sprocket at the engine end of the primary chain.
Install the H-D 34761 or equivalent tool and compress the clutch spring. Remove the snap ring and then back off on the tool to release the pressure on the clutch spring. Once the pressure has been removed, remove the adjusting screw assembly, the outer clutch spring seats, the clutch spring, the inner clutch spring seat, and the pressure plate.
Then you can disassemble the rest of the clutch. Remove the remove the four friction plates and three drive plates. Then you can remove the spring plate and the remaining plates after that. Remove the snap ring that holds the clutch assembly onto the transmission clutch gear and remove the inner and outer clutch shells, the primary chain, and the engine sprocket as a group.
For this job, I would recommend that you purchase a service manual. It's has pictures that show you what you're dealing with and in this case, a picture is truly worth a thousand words.
Good Luck
Steve
Nov 05, 2010 | Harley Davidson XL Sportster 883...
Whats it take to install a clutch hub for a 1988 police bike flhpt
To install a clutch is not what I call an easy job but not an extremely difficult job either. You are going to need some special tools however.
The tools you'll need are an impact wrench, a large socket to fit the compensator nut and one to fit the mainshaft nut, a primary locking bar, torque wrenches that will torque to 150 foot pounds and 70 foot pounds in the left handed direction, and a special tool required to disassemble the clutch assembly.
First, disconnect the battery, then drain the primary and remove the outer primary cover. Use the impact wrench and appropiate socket to remove the compensator sprocket nut from the engine shaft. Remove the snap ring holding the release plate in the center of the clutch assembly and remove the LEFT HANDED THREADED mainshaft nut. Take the nut off the chain tensioner and remove the primary drive (engine sprocket, adjuster, and clutch assembly) as a unit.
Now, using the special tool, compress the clutch spring and remove the lock ring holding the clutch assembly together. Disassemble the clutch and reassemble it with the new clutch hub. Reinstall the primary drive. Apply one line of Loctite 271 inside the mainshaft nut and torque it to 70-80 foot pounds LEFT HANDED. Apply two lines of Loctite 271 (red) to the compensator nut and torque it to 150-165 foot pounds. This is what the locking bar is for, to keep the engine from turning while applying the torque to these two nut. Adjust the primary chain and reinstallt the outer primary. Add about one quart of lubricant to the primary. Reconnect the battery. Adjsut the clutch and cable.
Good Luck
Steve
Sep 17, 2010 | Harley Davidson FLHRI Road King...
I HAVE A HARLEY SPORSTER 1200, WILL NOT SHIFT OUT OG GEAR, STAYS IN HIGH GEAR....HELP PLEASE..............
Sounds like the shifter pawl is broken. This is common in Sportsters. You'll have to pull your primary drive to repair it.
Disconnect your battery, drain the primary, loosen the primary chain adjuster and remove the outer primary cover. Take the engine sprocket nut loose. Remove the snap ring in the clutch assemble and remove the throwout bearing. Remove the mainshaft nut that holds the clutch assembly on. This nut has LEFT HANDED threads. Lift the engine sprocket, primary chain, and the clutch assembly out of the primary case.
Now, you can get to the shifting mechanism and determine what the problem is.
Good luck
Steve
Aug 31, 2010 | Harley Davidson XL 1200 L Sporster Low...
Disassemble the clutch so I can install new primary chain
Isn't there a big nut in the middle of the clutch pack? Also I am not sure, it might be a left-handed one, check the threads first.
May 12, 2010 | 1993 Harley Davidson FXR Super Glide
HANGS BETWEEN GEARS, MANIPULATE THE SHIFTER UP AND
Sounds like you have some shifter pawl problems. If you remove your outer primary cover, you can see the shifter pawl just behind your clutch assembly. The problem could be the shifter pawls, the springs, or the carrier. You'll just have to go in there to find out exactly what it is.
To get the outer cover off, first loosen the primary chain tensioner beneath the primary cover. Then remove the large round cover from the outer primary cover. Beneath the cover is a spring with a locknut over the clutch adjuster. Drain the oil out of the primary and remove all the bolts around the primary including the left side foot rest and the nut at the front. Slide the outer primary cover off as you turn the clutch adjuster clockwise.
With cover off, you may can see the problem with the shifter pawl but I'm afraid that you're going to have to pull the engine drive sprocket and the clutch assembly off to repair it. To do this, you need an air wrench to remove the front sprocket nut and the clutch assembly nut. The clutch assembly nut is left handed threads. Take the snap ring out of the center of the clutch assembly and remove the clutch adjuster plate.
When reassembling the primary, torque the engine nut to 150-165 Foot pounds, the clutch nut torque is 70-80 foot pounds left handed, adjust the primary chain to 3/8 to 1/2" up and down with the engine cold. Check the primary chain adjustment thorough the upper inspection hole on the outer primary cover. I highly suggest you purchase a service manual to refer to if you decide to do this job. If you do it yourself, the book will pay for itself with this one job. Otherwise, this is a pretty advanced job and you might be better off taking to an experience mechanic.
Apr 01, 2010 | 2003 Harley Davidson XL 1200 S Sportster...
Need 2 replace clutch on my 2001 softail duece
Remove the outer primary cover on left side. Don't forget to drain the oil first. Using a large pair of snap ring pliers, remove the clutch adjuster plate from center of clutch assembly. Remove compensator sprocket nut (very tight) and the clutch hub nut (left handed threads) and remove nut from bolt on primary chain adjuster. Grab the compensator sprocket and clutch assembly and lift out of inner primary.
Jun 30, 2009 | 2000 Harley Davidson FXSTD Softail Duece
Arctic Cat 2007 Bearcat 660 Turbo WideTrack Articulating Rail Logo
1,158 people viewed this question
Top Arctic Cat Winter Sports Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
