Do you know or do you have a manual for an Elna 624 limited edition serger. I AM LOOKING FOR THE 2 OR THREE pages which show the settings for A THREE THREAD OVERLOCK RIGHT HAND NEEDLE FOR Blanket.
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
are you using a wire threader or tweezers to thread up? also some overlockers have a slide mechanisim on the looper so you can get to the eyelet, not familiar with this model but your manual should show the threading method. I usually turn the flywheel so the lower looper is all the way to the left and thread up the lower thread carrier, then turn flywheel again to move it to the right, then using the wire threader, I hook the thread from the left and bring it over to the right side, then thread up the looper eye. Hope that makes sense to you
The original manual is out of print and all that is available now is photocopies and they cost about $15. Let me know if you still need it and your zip code so that I would know how much postage would be.
