Question about Baby Gear
My stroller is stuck in the open position and wont collapse. How to collapse my stroller?
Stroller was opened to wheel to garage. Left in garage for maybe 30 min while an errand was run. Went to put stroller in car. Would not collapse. Worked fine before. Tried collapsing it like I always do, but nothing worked. Stuck in open position.
momsjustknow
  • 135 Answers
SOURCE: how do you collapse this stroller?
I haven't seen one of these in awhile, but I believe that you click a button down by each rear wheel, possibly labeled 1 & 2 and there also may be a safety catch on the side after you start the fold that you will need to release. Also, you can go to www.perego.com and see if they have the user manual posted on the website for download. They have most manuals posted on their site if I am not mistaken.
Good Luck! from Moms Just Know
Posted on Oct 24, 2008
  • 419 Answers
SOURCE: how do i lock the stroller when closed/collapsed.
It will depend on which model you have. If you have the older version, then there will be a nylon strap (usually found around the bag at the back of the chassis) this strap has a black plastic snap lock on that will go around the handle bar when closed and keep it closed.
If you have the newer version, this will automatically lock shut via a grey plastic clip on the side of the chassis.
I hope this helps.
Posted on Nov 04, 2009
  • 25 Answers
SOURCE: how do you collapse the stroller?
theres a switch u pull on the bottom of the wheels if not its in the back of the stroller
Posted on Apr 08, 2010
  • 366 Answers
SOURCE: opening stroller
Please slip the levers off and then straigten the rods and lock the levers again.
Posted on Jul 01, 2010
  • 42 Answers
SOURCE: trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
Posted on Jul 08, 2010
The left side of the handle bars of stroller will not open to full position and the rest of the handle bars are too low (by my waist). The stroller was fine and the next time I used it this happened. The...
The only thing I can think of is if it is bent, to try straightening the bend. Be very careful as the frame is hollow and too much pressure will cause it to collapse. Do not try to use a hammer as this will collapse the frame. If you do not have the strength to bend the frame, ask someone you know to help you.
Best of luck Jamie!
Jim
May 31, 2011 | SafeTech Double Jogging Stroller
How do I make my Peg Perego AT 4 All-Terrain Stroller front wheels turn? Any modifications possible?
There is two models of AT- stroller-youngest version and oldest- oldest version has'nt posibility to turn front wheels, but if you have youngest version you need to find keylock-its positioned in left side of stroller,near botlle holder. On lock you have a simbol of opened or closed padlock-when you turn to open padlock-wheels will turn.
Mar 07, 2011 | Peg Perego AT 4 All-Terrain Stroller
Opening stroller
May 12, 2010 | Graco DuoGlider - Melbourne Standard...
Our zooper boogie red jogger stroller has had problems for a long time, the front wheel is very hard to push and lock, the whole stroller seems really hard to handle, it just wont turn or go where it needs...
Hi I had a similar problem with mine. I ended up just tightening the cable that connected the front wheel to the lock. (screw-like connector bolt under lock) You may want to adjust the cable as well sounds like it needs to be loosened maybe. I hope that I helped. Good luck! :)
May 03, 2010 | Zooper Boogie - Red Jogger Stroller
What is the best position for the seat back to be in when closing the Chicco Cortina stroller? When I collapse the stroller using the handle, there is some resistance before it locks into the closed...
The seat back position isn't important. What IS important is the position of the stroller handle (not the one used to collapse the stroller).
If the handle is left up while collapsing, the stroller should fold easily. If the handle is down, it can get in the way and cause the process to be more difficult.
I have to take most of the removeable parts off of mine in order to fit in in the back of my coupe.
Oct 14, 2009 | Chicco Baby Gear
How do i collapse the buzz modelof the quinney pram
check the manual at www.quinny.com and there are some good you tube videos as well but basically, stand by the front wheel, position the seat slightly reclined and forward facing. Press the buttons on each side of the seat and pull the hinge forward and down. Make sure it clips shut or it will spring open again.
Aug 02, 2009 | Quinny Freestyle 3 XL Stroller
Fold and lock stroller
The handle twists after you press the red tab on handle, there should be a red little flap than is the way to hold collapsed. A bag???? buy a hockey duffel.
May 18, 2009 | Graco Quattro Tour Deluxe Travel System -...
Collapsing the stroller
If your wheel is in the locked position it won't collapse all the way. Make sure the wheel is in the swivel position and that it is facing out. Hope this helps!
Littlema
Apr 16, 2007 | Baby Jogger City Twinner Stroller
Baby Gear Logo
121 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
