Question about Garden
Replacing pull cord on an etesia lawnmower - Garden
  • 84 Answers
SOURCE: lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Posted on Jun 24, 2009
harlan301
  • 205 Answers
SOURCE: How to replace the pull cord on a Scotts lawnmower
pull the starter housing off, take out the old rope, rotate the starter counter clock wise 5 to 6 times were the to holes line up stick a screw driver throw the holes to hold it in place. feed the same ty-ip rope from out side in throw then tie off. your going to need about 6 to 7 feet. let the pulley pull the rope in
Posted on Oct 13, 2009
Knucklebstr
  • 222 Answers
SOURCE: How do i replace pull cord on lawnmower?
The best way for me to tell you is to show you a video on YouTube. There are a million of them, but I'll link you to 2 of my favorites because there are actually two different ways of doing it, depending on your setup. Click the links and enjoy; best of luck to you.
http://www.youtube.com/watch?v=GyjQir3b3xI
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Posted on Jul 02, 2011
  • 6468 Answers
SOURCE: Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
Posted on Apr 02, 2012
wadingriver
  • 2069 Answers
SOURCE: pull cord on my lawnmower is inoperative
You need to take the Starter cord assembly off and see if the Nylon gearing that 'grabs' the centrifical wings is broken OR those wings are rusted in a way that they do not make contact with the nylon piecs of the Starter.
Posted on Dec 11, 2012
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
Etesia lawnmower
Check to see if choke is closing and opening properly, if yes, adjust the carburetor as it appears you are not getting enough fuel flow with the amount of air intake.
Jun 07, 2013 | Garden
Etesia drivebelt
This is posted in the wrong product category, please post again.
May 26, 2012 | Cars & Trucks
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Sep 20, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
