Question about Ovens
How long do I cook a leg of lamb in a fan oven weigth2.235
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
Why does the fan not work in main oven while cooking, book says fan assisted oven, only see it working on rapid preheating to heat oven first. is it meant to work while cooking in main oven
A lot of ovens have a convection option, and the fan will only work in this position. Otherwise, just rotate your pan halfway through, like we always did.
Dec 27, 2014 | Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
Bush ae56tcs the oven has suddenly stopped working. The light and fan isnt going on either. Everything else on the cooker is working (ie the grill and hobs)
-Check the breaker on the electric panel. Possibly two legs breaker, one pop out but still one on. you still have power but can't cook.
Good luck
Mai Lor
Nov 08, 2014 | Ovens
Hi there, Neff B1432 was working perfectly this afternoon, but this evening when cooking 2 racks of lamb it wouldn't heat up higher than 50 degrees. Sounds like the thermostat...is this an easy job to...
Could be a faulty thermostat, but I would check that element is getting hot before commiting to replace the thermostat.
Run it for a few minutes and feel to see if you can feel hot air blowing from fan at rear of oven. If no heat present, thei it will be the elemnt that is faulty.
Jan 06, 2011 | Neff B1432 Single circotherm plus Electric...
Is there a way to turn off the fan in the oven, and still use the oven to cook? My oven is far too fierce.
Unless your fan oven specifically has a control to turn off the fan, then the answer is "no". Disabling the fan will cause the element to overheat and fail.
Fan ovens are far more efficient for most types of cooking, but you have to adapt by using either shorter cooking times, lower temperatures or both. Many ready meals have separate fan oven instructions for this exact reason and you can search the web and buy books for recipes and methods specifically aimed at fan oven users. Once you're used to fan cooking you'll hate using regular ovens again.
I hope that you have found my answer to be of use and ask only that you return the favour by rating my answer.
Oct 24, 2009 | Ovens
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Seems to be taking a long time to cook
To preheat oven just select the temp you intend to cook at and wait until the red light goes out,it is then preheated
Then you can put your food in and carrying on cooking.
Yes you do put it on fan symbol, but make sure it is on the right one , as some ovens have fan only as well as fan and heat.
Plz rate this solution.
thanks.
Dec 14, 2008 | Ovens
Power running through neutral wire
If you are getting power on the neutral that usually means the neutral is open (broke). To confirm this check the voltage on your 2 hot leads. You may need to check the voltage when the oven is on. You may find high voltage on one leg and low voltage on the other. The high voltage would fry a fan (so would low voltage for that matter). I hope this helps. Sorry I don't know more.
Jan 30, 2008 | Ovens
Ovens Logo
53 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
