Question about Harman Kardon HK595 Computer Speakers
How do I plug HK-595 speaker 3 wires into Dell XPS 8700, the color codes don't match.
How do I plug the 3 wires from speakers into Dell XSP 8700?
Anonymous,
Below are the jacks for the sound card. Hopefully, it will help you get your speakers connected to the correct jack.
Realtek ALC3861 7.1 integrated audio
Gray = Middle surround out
Black = Rear surround out
Orange = Subwoofer and center out
Pink = Microphone
Green = Stereo out, Front Speakers, Headphones
Blue = Stereo in
25627675-cmq4uuvgx1xlr2vsmpalf0ir-5-0.jpg Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 04, 2015 | Dell Audio Players & Recorders
Xps 8700 five beeps and five beeps starts windows goes to power save mode
Sundeep B posted this July 2013 on the DELL.COM>Community>Support Forums>Desktop>Desktop General Hardware Forum
DEL5 beep error code indicates an issue with RTC power and indicates an issue with CMOS battery. You may try reseating CMOS battery. You may refer to Owner's Manual Here. The location of CMOS battery is as shown below :
The video cards mentioned by you should function properly, however, Dell has tested XPS 8700 only with following video cards :
  • nVidia GeForce GTX 660 GTX 645 GTX 650Ti GTX 660
  • AMD Radeon HD 7570 HD8870
Dec 10, 2014 | Dell XPS 8700 Desktop - Windows 7
Dell xps 8700 diagram
is your system turning on or no?
can you see your operating system?
May 20, 2014 | Computers & Internet
Dell 5650 speakers
Try plugging into light green if basic card or integrated system (built into motherboard). If it is a aftermarket Card Check owners Manual on CD that came with card or go to MFG website and search your with your model # for manual and/ or specifications on hardware.
Apr 14, 2014 | Harman Kardon HK595 Computer Speakers
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
HK 595 speakers
It should,but will depend on the output jack itself,If it is only a stereo output,it will only allow for a 2 channel plug.
If the output jack is for surround sound,it will work with the 3 into 1
Please rate this fixya solution.
Jan 21, 2009 | Computers & Internet
Trying to reconnect a set of Harman Kardon candlestick computer speakers to a Dell Dimension E520 computer. I got three plugs and dell has 6 holes...what the heck goes where? Nothing I seem to try works...
Hi rjlevesque
For the speakers, you need only connect to the GREEN jack at the back of your computer. It's OK to leave the others blank.
Your two HK speakers will, with one wire, connect to each other and, w/ another wire (usually having a GREEN connector on the end), connect to the computer.
I'm not sure what the 3rd wire is unless it's (1) the power connector or (2) for connecting to a sub-woofer.
Does the speaker set include a sub-woofer? Or does it include a "surround sound" or 3rd speaker?
You can find pics & symbols (the symbols are helpful if your sound card jacks are not color-coded) for (3) of the most common audio connections HERE.
Usually the color of the connector on the wire is matched to the sound card jack w/ the same color. (green to green; pink to pink; blue to blue).
green = speakers
pink = mic
blue = line in
Make sure you are connecting to the active sound connectors - the ones you used b4 the HK speakers.
If you have "integrated audio" (audio that is built into the motherboard) and you have an audio expansion card installed on the computer as well, one may be disabled or not selected in your computer's audio configuration.
If that's the case (that you have two sets of audio jacks to choose from), try connecting the speaker wire from the HK speakers 1st to the green jack (or the jack marked w/ the symbol of a speaker) at the bottom of your computer. (There'll only audio jacks here if there is an audio expansion card installed on your computer.)
If that is the case, there'll be other (usually) colored jacks running horizontally next to the speakers jack.
If you still have no sound, connect the speaker wire to the GREEN jack that is (usually on Dells) up by your PS2 (round - one purple and one green) keyboard and mouse connectors (also at the back of your computer). The other jacks in that set (of audio jacks) will be situated vertical to one another and on the left-most side at the back of your computer.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Harman Kardon HK595 Computer Speakers Logo
141 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
