Question about Philips Televison & Video
My Philips 32 TV 32PFL9604 keeps resetting picture to a less bright/vibrant picture with poor white definition..If possible can I reinstall the software via a download to try and resolve this issue
    Master:
  • Philips Master
  • 487 Answers
Discuss this with Philips customer support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Posted on May 05, 2015
SOURCE: Sound quit working
I have the same problem with the same TV (16 months). So far the only option ive came across is just hooking up a surround system to the cable box for the audio.
Posted on Sep 03, 2007
roety
  • 585 Answers
SOURCE: No picture on Samsung LNS4051D HD TV.
Maybe the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
Posted on Aug 01, 2009
  • 5 Answers
SOURCE: 32" philips flat crt PINK SCREEN
The set has detected a problem internally and does not "start" to precvent further damage. i would take it where you got it sweety
Posted on Sep 05, 2009
  • 8457 Answers
SOURCE: Philips 42PFL3603 tv sound but no picture.
Return it to waranty repair or replacement ur video backlight inverter board is dying going to be dead,than u have no video(picture at all)might just sound.
Posted on Sep 27, 2009
SOURCE: I have had this 32
i need to hook up a 3 way switch
Posted on May 01, 2010
Poor picture quality on alba LCD TV after recent digital switchover.
Digital TV uses less airspace than analogue TV, so after the digital switchover there'll also be more room for services such as high-speed mobile broadband and high-definition television (HD TV).
Sep 16, 2012 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
The picture is almost hazy and is kinda dim. picture not bright??
have you tried to take off the front screen and clean the lens and mirrors yet? if this is a philips 9or a magnavox you will most likily need to change the fluid inside the picure tubes
May 08, 2010 | Televison & Video
JVC 32" CRT TV BLURRED PICTURE POOR TEXT QUALITY POOR IMAGE DEFINITION CANNOT IMPROVE USING NORMAL COMMANDS
Seems to me you should have to contact a technician to adjust manually the circuit side of it. Usually the screen and focus control knob on the flyback to adjust the settings.
Sep 23, 2009 | JVC AV-32D305 32" TV
Bad DVD picture
please reset the factory seetings in uer dvd player, throgh menu button on uer remote. Firstly open uer tray and after take rhe menu and select factory reset, and reset it,
Mar 02, 2009 | Philips DVP5140 DVD Player
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Tv showing blue screen with flyback lines sound ok
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Dec 27, 2006 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
