Question about Samsung Hlr6167w 61-inch Widescreen Hdtv Dlp Tv
My TV takes 20 minutes to turn on - Samsung Hlr6167w 61-inch Widescreen Hdtv Dlp Tv
  • Samsung Master
  • 1,928 Answers
The power supply have sometimes used TAIWAN CAPACITORS they must be replaced in the power supply board most are the tolerances of the capacitors in voltage too tight. if you replaced the capacitors 10 v to 16 v and the 25 to 35 v models then the format of the cup it is not to big. 105 or 85 degrees capacitors of a good factory make working the tv for years but also if there is someone who will repair then also replace the capacitors in the circuit who looks the same size and voltage of the backlight inverter because to protect of the very sensitive step up transformators that will get to high voltages and will damaged in some time if you forget that. Samsung have most of the times bad capacitors and also some 2 watt resistors in mains secundary replace also a few because the 2 watt resistors of samsung are not to trust. in mains, replace with every other resistor of 2 or better 3 - 5 watts .
Posted on Apr 04, 2015
Tv takes 20 minutes to turn on, keep hearing a clicking sounc
Ur tv the Ballast board the help to turn on the tv projection bulb is dead.Try website like Tvrepairworld.com to buy the Ballast board for the replacement.The Samsung/Akai tvs use the same Ballast board.When in the website go to the menu that said Samsung/Akai circuit boards.Pick that option click on it,u will see a picture of a Ballast board look like.
May 31, 2010 | Samsung HCN4226W 42" Rear Projection...
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My sony has started turning itself off after 20-30 minutes, each time you turn it back on it will turn itself off after a shorter and shorter run time. Leave it over night and it will start the next day...
It might be over heating. If there is a lot of dust
inside of the back of the T.V. you should take it outside and blow it out with an air compressor.
good luck
Aug 06, 2009 | Sony KV-36XBR400 36" TV
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Tv turns on but takes about 20 minutes to show the picture
This is the picture tube. If you check shops you can find one that has a picture tube restorer. If they run just the cleaning process it will buy you some time. This is good some times for up to a year
Apr 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When I turn TV O
When i open it screen takes 15-20 minutes to be displayed complete.sound & other things are ok.So i request to have sansui tv service dealer in Mumbai/Navi Mumbai/Thane India No; to contact. Regards M.w.Ahmed
Mar 02, 2007 | Sansui LCDVD200 20 in. TV/DVD Combo
Samsung Hlr6167w 61-inch Widescreen Hdtv Dlp Tv Logo
67 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
