Question about Samsung RS2630SH Side by Side Refrigerator
Unplugged frig and now it won't cool. Only has blinking lights on front panel.
  • Samsung Master
  • 5,323 Answers
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 28, 2015
2 Suggested Answers
  • 26 Answers
SOURCE: months old...wont cool. Freezer and frig both
if months old only, call for warranty
Posted on Mar 16, 2011
Timer light blinking and tv won't turn on
Not much info to go off of, and the video is a bit blurry. Try unplugging the tv for a minute or two, make sure to leave it unplugged to allow power to dissipate. Then try again. Otherwise I would suspect power supply problem.
Apr 10, 2013 | Televison & Video
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
When the frig is turned on the frig light blinks and the alarm light flashes no compressor runing
That's a sign of an overload on the frigerator's compressor. The cooling fan might not be working. Compressor needs to be checked by your technisian.
Jul 30, 2009 | Refrigerators
Frig stopped cooling, unplugged & replugging worked - now what?
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Apr 10, 2009 | Kenmore Refrigerators
Error code hrs is blinking, frig is not running.
ERROR CODE HRS IS BLINKING, FRIG IS NOT RUNNING.
Aug 29, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
