Question about Garden
How many cm in 38 in - Garden
    Problem Solver:
  • 19 Answers
96.52
Posted on Apr 05, 2015
Tip
How to Build a Sawbuck for Cutting Firewood
Select the size. Design the permanent sawbuck to be 6 vertical 2x4's (38 mm x 89 mm) or 2x6s (38 mm x 140mm) of about 4 feet (1.22 meters) long and 4 horizontal 2x6's 5 feet (1.52 meters) long using 3.5 inch (8.89 cm) wood screws or nails. (See "Tips" for information on making a demo/prototype version instead.)
* Cut the "V" form portion at an angle as shown
* Place the middle of the "X" a little taller for use with a chainsaw rather than for a bow saw, if you prefer.
Design the sawbuck/sawhorse as shown in the illustrations. Tailor the design as you desire or require.
Use suitable boards for your project. Nominal 2X6s or 2X4s of pine (southern yellow or lodgepole or white), or spruce will be fine.
  • Decide the taller height that you think you may want, namely, cut the "X" pieces about 48 inches (1.22 meters) long.
  • Adjust the height according to what feels right to you.
Consider starting with one (the first) "X" temporarily attached together with two nails/screws to see how tall and wide that you want to make it. Take it apart and angle-cut and trim the angle of the "V" as shown in the photo above. This angled cutting of the "V" will make it less top-heaUse this as your pattern for the rest. Feature: the "V" part allows you to nestle and cut two or more narrow poles or tree limbs (around 3 to 8 feet (91.44 cm x 44 meters) in length) with a chainsaw, to make your firewood quickly.vy.
Design the sawbuck lower if you are using a smaller "X" sawbuck with a hand "bow-saw". Make the sawbuck about only 20-24" (50.8 cm x 60.9 cm) high to the center. This will allow the user to put a foot on top of the poles or the split wood being cut, when it is that low (as illustrated).
Design a wide, heavily braced base to give you more stability for the power of a chainsaw.
Caution: A lightweight sawbuck might lead to an injury if it falls over while cutting. Don't use a smaller sawbuck for chainsaw work.
Make the sawbuck fold if wished. One way to connect the sawbuck together is to use one big bolt of about a 4 inch (10.16 cm) long, and 1/2 inch (12.7 mm) in diameter. Put it in the exact same placement at the center of each "X", using extra-large washers, so that it can be clamped together and loosened to fold for storage. Consider screwing on a leg spacer-brace on each "X". Then unscrew the end spacer-brace to allow the "X" to fold. To build a non-folding sawbuck, simply connect the "X" forms together, and use 4 to 6 nails/screws driven permanently into about the center of each "X".
on Jun 19, 2010 | Heating & Cooling
Can i ask a silly question do i need two stroke oil with this model i think people are winding me up
Engine
Engine type Liquid-cooled, 4-stroke Parallel
Twin
Displacement 649 cm³
Bore x stroke 83 x 60 mm
Compression ratio 11.3:1
Valve/Induction system DOHC, 8 valves
Fuel system Fuel injection: ø 38 mm x 2
(Keihin)
Ignition Digital
Starting Electric
Yes they are!
Mar 11, 2011 | 2006 kawasaki ER-6f
Engine
Twin
(Keihin)
Ignition Digital
Starting Electric
Mar 11, 2011 | Televison & Video
Where can convert european shoe sizes to american?
Here you may find a convertion table for shoe sizes.http://www.dancesport.uk.com/shoes/conchart.htm
Oct 27, 2010 | Clothing Accessories
Agasta ant starts at one edge of a placemant, 29.6 cm wide. she travels at 1.40 cm/sec at 52.o degree from one edge. how long will it take her to get across the width?
draw a right triangle. The bottom of the triangle is 29.6 cm and the angle is 52 degrees (from the other edge). note: triangle not to scale.
|52 \
|_____38\ 52|
29.6
Therefore the inside of the angle is 38 (90-52) and the opp angle is also 52 (90-38)
sine = opp / hyp therefore hyp = opp / sine
length of hypotenuse is: 29.6 * sine 52 deg.
therefore the length of the hypotenuse is 23.32511 cm. the ant travels 1.4 cm / sec so the ant travels to the other edge in 16.66 seconds.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
I need the 4 castors/ wheels for a Promac PM 38 CM
You will probably have to contact the manufacturer to find a dealer in your area that carries replacement parts or they can sell them directly to you.
Apr 09, 2009 | Promac PC10MP Air Conditioner
Trying to use a Zebra ZTC ZM400 with an AS400
I was having same issue printing from our AS400's as well.
Issues was resolved by installing latest Zebra ZM400 firmware.
We were on ver V53.16.3Z but upgrading to V53.16.4Z seems to have resolved it.
Good luck.
Jul 03, 2008 | Office Equipment & Supplies
Olympus fe-210
aqui alguna caracteristicas, si parece bastante interesante.
7,1 megapíxeles
bulletpoint_blue.gifZoom óptico 3x (equivalente a 38-114 mm en una cámara de 35 mm)
bulletpoint_blue.gifPantalla LCD de 6,4 cm / 2,5”
bulletpoint_blue.gifValor ISO elevado
bulletpoint_blue.gif15 modos de escena
bulletpoint_blue.gifModo Super Macro desde sólo 5 cm
bulletpoint_blue.gifMenú multilingüe con 25 idiomas
bulletpoint_blue.gifCámara también disponible con el nombre X-775
La estilizada y ligeramente sinuosa Olympus FE-210 reúne buen precio, rendimiento y facilidad de uso. Sus 7,1 megapíxeles y zoom 3x garantizan un excelente rendimiento. Los resultados se pueden ver en la gran pantalla LCD de 6,4 cm. La calidad de imagen está muy por delante de dispositivos como teléfonos móviles – de manera que se pueden guardar las imágenes con toda seguridad e imprimirlas en gran formato.
Saludos
Sergio
Feb 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
