Question about Cooking
How to reheat pre cooked scalloped potatoes, should i add more cream on top? Microwave or oven?
    Scholar:
  • 99 Answers
A lot of people really don't know how to reheat things in a microwave. They stick the food in, hit the amount of time they want and it comes out hard and dry. Well, at 100 power, you're cooking stuff. Cover your food with a piece of waxed paper and heat at about 40% power. Depending on the size of the food, of course the time varies. You shouldn't have to add anything else if you cover the food so it doesn't dry out.
Posted on Nov 22, 2017
MicrowaveSvc
  • 9085 Answers
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: JVM1740SM1SS
Your membrane keypad has probably failed.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
prototech@usa.net
Posted on Jun 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: sylvania microwave
They have that manual their site, but it's only in French!
If you don't speak French, then visit the manual download page and put in only "SM807" in the search box.
The manual for either the SM80703 or SM80704 may be close enough to yours to work.
You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
  • 360 Answers
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Posted on Feb 08, 2009
SOURCE: NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Posted on Jun 08, 2009
How to bake pizza in rival micro wave .??how to set it?
Unless the pizza was specifically packaged for microwave use, pizza cooking in a microwave is usually a bad idea. They don't turn out well. Although microwaves are referred to as "ovens", they really don't bake things, they boil them by heating the moisture in the product. Thus, pizza crust will not rise and get crispy unless the pizza was pre-made to be microwave reheated. Those pizzas will give instructions on how to microwave them.
Nov 06, 2015 | Rival Microwave Ovens
I have made potato &leek soup with pre packed veg why can I not reheat it
perhaps the microwave oven is broke what you heat doesn't stop it from working .
Mar 14, 2015 | Microwave Ovens
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
What is the difference between a stew and a casserole?
A stew is cooked on a stove or over a fire and a casserole is cooked evenly in an oven. As well, casseroles are cooked either covered or not, while stews are usually covered so they don't evaporate.
Jan 14, 2013 | Home
Hi can anyone help please i dropped my ks360 in som water but now the phone wont switch on at all the phone and screen does come on and works fully only if the charger is plugged in as soon as i take the...
Dip it in Ice Cream, and then in the microwave inside a potatoe cook on Turbo Heat for 1 min 30. The Ice Cream gets sucked into the potatoe leaving a hot phone, cooking it with a Microwave helps release the carbonic trioxide structures that water produces leaving you with a working, waterless phone. Duh!
Apr 20, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Preheated oven with glass dish...tried to bake..now no power
they have a fuse that blows if the cavity gets to hot looks like a small thermostat
Jun 30, 2009 | GE Advantium SCA1001SS Convection /...
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Cooking Logo
805 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
