Question about Dell PowerEdge 2600 Server
Disk 4 "is not ready"
The integrated LSI Logic RAID controller reports Disk 4 "is not ready" (no amber light) but it does detect it on controller initiation. I need to find out if I must rebuild the array, and if so, might anyone know how? I don't see any array utility in the LSI logic BIOS. Is this simply a backplane with a software-controlled RAID solution? The information I found seems to say this: "Figure 7-4. Removing and Installing the RAID Battery: .... Step 15: Install the RAID software." -- https://cs.uwaterloo.ca/~brecht/servers/docs/PowerEdge-2600/en/Pe2600/IT/5j721c70.htm#1058064
    Genius:
  • Dell Master
  • 1,552 Answers
Even when the drive is not spinning, it will identify itself (manufacturer, capacity) when queried. So, it's possible that it "checks-in", but files/directories on it cannot be read.
Posted on May 10, 2015
5 Suggested Answers
  • 159 Answers
SOURCE: problem with creating array
Ctrl M during power up ..
Posted on Nov 29, 2008
JaxPlanet
  • 922 Answers
SOURCE: I need a Dell PE6300 Server Assistant CD
Good news, Dell has lifetime phone support for their servers.
Write down the Express Service Code and Service Tag number that is on the server chassis and call Dell.
This is the last number I used for server support: (800) 945-3355
If it doesn't work you should be able to find a valid number at support.dell.com
I hope this helps.
Posted on Jul 23, 2009
sys_admin
  • 829 Answers
SOURCE: can I install sco open server 5.0.5 on poweredge
Hi ,
You can move a program from sco openserver 5.04 to newer platform it supports RAID controller.
Posted on Jan 29, 2010
ded_ch
  • 12 Answers
SOURCE: Dell poweredge t110 Raid 5
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
Posted on May 02, 2011
Controls perc 3 is beeping. Server runs fine. What should I do to correct drive if failing?
You should first look at the drives on the front of the server to see if there are any failure lights.
If not, then it may be a RAID battery that is indicating failure.
Either way, this is probably an LSI RAID controller. Even after you correct the issue, you may still have to use the RAID utility (megacli in Linux) to silence the alert.
LSI is quite inefficient about their RAID controller and how they handle the issues.
Apr 26, 2014 | Dell PowerEdge 1300 Server
Raid configuration
That's probably because RAID 5 only tolerates 1 HD failure, (unless you have hot spares, in which case you can have many failures -provided only one fails at the same time...).
RAID 5 arrays can tolerate no more than one member drive failure.
Nov 08, 2013 | LSI Logic Computers & Internet
Can a raid5 be expanded to include an additional disk on the dac960prl or must the raid be destroyed and re-created?
As a rule of thumb, a raid 5 array can be expanded to include additional drives. This is done during the boot process and then going into your RAID controller setup. You would then go into the RAID configuration and add the new drive to the array. This was the simplified explanation but i think you get the idea.
Things to consider,
DO NOT remove the RAID array unless you dont care about losing data.
DO NOT try to add a smaller drive than what is currently part of the array.
When possible, the new drive should be identical to the existing drives, but I have added same size, same speed more than once and it will work.
All of the drives you want as part of the array must be on the same controller.
Hope this helps,
Brian
Jun 30, 2010 | LSI Logic Mylex AcceleRaid 150 DAC960PRL...
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Problem with scsi driver proliant ml 370 for NT4
Are you attempting to boot from the Windows CD?
If you are booting the server from a Windows installation disk and it is unable to detect the hard drive, this typically means the following things.
You need to provide the driver for the RAID controller of the server (this can vary, depending on the version of the ML370 e.g. G4/G5)
If it still cannot detect the hard drive after providing the driver for the RAID controller or if there is not a driver available for NT4, it may not support the controller.
In this case you can remove the RAID set by entering the RAID setup (could be LSI or adaptec). NOTE THIS WILL DESTROY ALL DATA ON THE DISKS THAT ARE A PART OF THIS RAID SET.
Dec 26, 2008 | HP Compaq ProLiant ML530 Server
Raid 0 on Intellistation 6221?
That particular work station comes with both IDE and SCSI drive interface controllers. The IDE drive should be used for your OS. The SCSI drives for your data storage. Now, the issue is to get the SCSI to work in RAID_0 as I understand.
You iwll need a RAID controller such as Adaptec AHA-3940AU WD SCSI Host Controller, which may be found on eBay (used) for a very affordable price. The driver software may be downloaded directly from Adaptec, so I suggest you do that in the iterim peroid, and store drivers on a USB thumb drive.
Hope this helps you.
Dec 21, 2008 | IBM IntelliStation Z Pro 6221 PC Desktop
Raid config problem
download a driver over the net
Feb 21, 2008 | HP NetRAID-2M SCSI Controller
Dell PowerEdge 2600 Server Logo
476 people viewed this question
Alun Cox
