Question about Olympus AS-2300 PC Transcription Kit
I installed the software. Pedal works but no sound coming out of the headphones
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
My headset is not working
Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Jan 16, 2013 | Computers & Internet
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Hello, I can't get sound to my laptop. when I go into the sound controls it's set for Internal but doesn't give me the option to change it?
Check the Sound driver in Device Manager.
Obtain and install the update Sound driver from drivers page.
Open www.hp.com type the product number (eg: AB123UA) in the search field >> Software and Drivers >> Select OS >> Audio driver and isntall it. Restart.
Next...
Restart Audi service
1. Windows key+R. services.msc and press enter.
2. In the right pane, double click on Windows Audi.
3. Stop and then Start. Select Startuptype: Automatic.
4. Apply | Ok.
Next...
Connect an external headphone and check for sound, if working.....
Connect External Headphone.
Play some musich and as soon as the Music starts
Removet he headphone with a slight ****. Check if sound coming from Speaker.
Next...
re-install OS
Next..
Repair
Jul 24, 2010 | HP Computers & Internet
I cannot get sound from my internal speakers on dell d600 latitude. Headphones work and sound comes out of internal speakers briefly when pulling jack plug out? So I know they work but just cannot get...
This sounds like a defective audio port. In normal operation, plugging in a headphone plug breaks the connection to the speakers. On your laptop, when you pull out the plug it makes a connection, but only briefly. Unfortunately the audio port is built into the system board. I don't think you will find a software fix for this problem. Your best bet is to get a USB sound device for external speakers.
Apr 27, 2010 | Dell Latitude D600 Notebook
Audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hi my headphone jack stoped working on my acer 3680 how do i fix this problem
Typicaly when a headphone jack stops working it means that there is a hardware issue. Check to see if you get sound from the PC under normal circumstances, (without headphones). If so... Your headphone jack may have come lose from the main board. In this case it will need to be taken to a shop to be re-soldered to the board, or just replaced with a new one. If you do not get sound even from the standard speakers, it very well could be a software issue, (currupted driver, etc.). In this case. Go to your PC's support page on the web and try re-installing the driver for your sound device.
Nate: Sanger, CA.
Apr 16, 2009 | Acer Aspire 5000 Notebook
Automatic not switch the headphone and notebook speaker
sound like u have to update your sound driver. try this link driver updater download it and install to your computer. scan your driver using after installing this software and then restart your computer. its work in acer laptop. might be it will work to your computer also.. cheers..
Mar 09, 2009 | Compaq Presario C700T Notebook
Problem regarding sound of system
THIS MAYBE IN A FEW PLACES CHECK THE FOLLOWING FOLDERS IN THE CONTROL PANEL.
DEVICE MANAGER
NETWORKING AND SHARING
PROBLEMS AND REPORTS
SOUND FOLDER
OFF CHANCE IT CAN BE SECURITY AND WINDOWS ANTIVIRUS PROGRAM NOT ALLOWING YOU TO MAKE THAT CONNECTION
YOU MAY COM OVER A RED X
THIS MEANS NO CONNECTION
YOU MAY FIND RED,YELLOW EVEN ORANGE CHECK MARK THIS STATES THERE IS A CONFLICK WITH THE SOFTWARE OR HARDWARE OR BOTH, OUTDATED DRIVERS MAY CAUSE YOU PROBLEMS, OUT OF DATE UPGRADES ARE NOT COMPATIBLE WITH NEW DRIVERS OR OPERATIONAL SYSTEM SOFTWARE. THE LIST MAY GO ON FOR A LONG TIME, JUST TAKE YOU TIME AND GET NEW UPDATED FOR ALL YOUR HARDWARE AND SOFTWARE UPDATES TO DAY AND EVERYTHING WILL WORK OUT FINE YOU'LL
SEE.
ROD
Feb 25, 2009 | Compaq Presario 700 470024-192 Notebook
My internal speakers have sound when headphones are used but no sound when they are used without headphones
my frnd the internal speaker will have sound by default it comes from dos...When it comes for headphones or speakers u have to install the sound drivers which comes from pc.....install it it will work...
May 20, 2008 | Gateway Computers & Internet
Open Questions:
See all Olympus AS-2300 PC Transcription Kit Questions
Olympus AS-2300 PC Transcription Kit Logo
153 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
