Question about Necchi Sewing Machines
I have been having trouble getting fabric to move steadily through my Necchi 535FA, perhaps someone can help?
I have tried what seems like EVERY combination of pressure settings on the bobbin and can't get it to move steadily. I have to keep trying to pull material through steadily while using right hand on the wheel to lower the needle as I press the foot control and it rev's up but does nothing! What's wrong? Never so many troubles with this. I have run a fresh bobbin and taken apart the bobbin to be sure it's placed right and even checked the threading all the way to the source. Please use plain language in reply describing HOW TO as you explain... that is, if anyone knows what I should do. I need to get this done today if possible! Or, if someone will call me I am at 513.266.6888 thank you. (Visiting my daughter, trying to finish for her to wear for her Birthday.) :)
  • Necchi Master
  • 1,860 Answers
The problem may only be with the feed dogs,, they feed the fabric thru so the needle can sew it.. if the problem persists the feed dogs need to be checked.
Posted on Jun 03, 2015
snakehead
  • 1074 Answers
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
Posted on Mar 19, 2007
SOURCE: tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Posted on May 09, 2007
kent581
  • 87 Answers
SOURCE: Bernina 1090 Needle assembly stopped moving down
There is a spring loaded catch on the needle bar assembly. It is designed to keep the needle bar from going up and down on command for basting. That way it can take fewer stitches while basting. Anyway, over time, with lint build up, use and not enough oiling, the needle bar clamp release can stick. It is located in the machine cover and hard to get at. It is located right at the point where the needle bar clamp (middle of needle bar) is. It looks pointed on top and about 3/8" tall and SHOULD be able to move front to back (as you are sitting at the machine. If you want to fix it your self, lay the machine on it's back to see up into the needle bar area, you can also see through the threading slot as well.to oil it with SEWING MACHINE oil (read not 3 n1 oil) and try to work it front to back until it breaks free and play with it until it springs back every time you push it. I hope this helps.
Kent
Posted on Mar 21, 2009
louislevel_2
  • 374 Answers
SOURCE: Manual wheel on side of machine won't move needle
hi there;
well try to rotate hand wheel center holder clockwise while hold grift the handwheel not to move to engage the clutch,because ther is clutch that holding the movement of the needle and the bobbins case.if still nothing change at all,open a cover motor assembly chech the belt tension if still engage on pulley,maybe slip pulley is occuring when motor run,if belt is slip to pulley replace belt,but if ok upon clutch adjustment ignore replacement.
regarding bobbin and threading you can watch on youtube.doing this,on internet explorer,type www.youtube.com
then on you tube search type"sewing machine"then click search
ther are high ligthed show for bobbins winding and treading just click it enjoy watching while you learn,have a nice viewing regards
don't forget to rate me,thank's
Posted on Apr 09, 2009
SOURCE: Lower Bobbin not threading
the thread will not catch the bobbin and the feeder will not turn
Posted on Jun 21, 2009
I need a manual on a necchi 535fa
Try this web site:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Jun 11, 2015 | Necchi Sewing Machines
I dropped the feed dogs on my Necchi 535FA to free motion quilt, but the material won't move. What else do I need to do?
MAKE SURE THE DOGS HAVE BEEN DROPPED. YOU NEED TO ALSO HAVE A PRESSURE FOOT THAT IS ROUND; ABOUT A DIME SIZE. ADJUST THE PRESSURE ON THE FOOT. IF YOU'RE WAITING FOR THE MACHINE TO MOVE THE MATERIAL IT ISN'T GOING TO HAPPEN. THAT IS WHERE YOU COME IN. MOVE IT WHERE YOU WANT IT. I HOPE THIS IS HELPFUL.
Oct 31, 2014 | Sewing Machines
Will a NECCHI 535FA sew denim jean material okay?
Use a heavy needle and a product called jean-a-majig from Joann fabrics and you will be fine, just make sure you use the correct needle as this is key
Aug 21, 2010 | Necchi 3101 Mechanical Sewing Machine
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Jul 07, 2009 | Necchi 6015 Mechanical Sewing Machine
Sewing Machines Logo
65 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
