Question about Konica Minolta Fusing Unit Bizhub C252 C250 4038075400
Error showing need to replacing imaging unit. follow the replacing instructions and close all doors
3 Suggested Answers
  • 44 Answers
SOURCE: installed the black imaging unit in konica bizhub
possible a bad image unit. you can try swapping the connector on the bottom of unit to see if it works.
Posted on Jun 28, 2010
bendarden
  • 984 Answers
SOURCE: install imaging drum Bizhub c352
The best way to solve your problem is to download the official Konica troubleshooting solution manual. It will tell you how to pinpoint and fix every problem reported to Konica. CLICK HERE
Posted on Jun 08, 2012
Konica printer showing multi errors i.e ask me to refill cartridge, close front door, paper jam and now constantly showing error of refill
First you replace the entire toner cartridge YOU DO NOT refill!!!!!! replace the entire cartridge with OEM cartridge not third party. Is the machine asking for toner or image units there is difference ???
WHAT would help is a model #######
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 10, 2017 | Konica Office Equipment & Supplies
I have an error message that says: please install the imaging unit correctly and close all doors.
Are you using a 3rd party image unit???, if so get OEM there are chips on them that copier monitors. The image units are the units below the toner cart. which one is having the problem Y M C or Black, did you re chip them, bad idea. Replace them with OEM cartridge.
Jan 14, 2016 | Konica Minolta bizhub C250 All-In-One...
Please install the image unit correctly and close all doors
replace the cyan image unit with OEM unit
Nov 15, 2013 | Konica Minolta bizhub C250 All-In-One...
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
It was showed an error code (D1.071B) by HP CM8050 displaying.
questions already been answered http://www.fixya.com/support/t8700781-code_d1_071b
May 09, 2011 | Computers & Internet
Error code C0F32
This error means Imaging Unit ATDC (automatic toner density control) failure. Open and close the right side door where the imaging unit is. If the code comes back you are going to need Imaging Unit service or possible Imaging Unit replacement. The best option and the cheapest is to locate a new imaging unit and replace it yourself. These units are very easy to change and similar to replaceing a toner cartridge in any laser printer. Just do a search for Di200 Imaging Unit.
Good Luck and Thank You for using Fixya.
Apr 14, 2010 | Konica Minolta DiALTA Di200 Copier
My Minolta CF1501 is showing error COF 34
Before doing above open and close the front door. The code is for the Auto Toner Density Control the black image unit if it comes back after opening and closing the front door the image unit needs replacement. You can't change the developer it is all one unit. the fuser has a different code 500 series. Dont mess with gain let machine run stablize.
Dec 24, 2009 | Minolta CF1501 Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
ERROR 22
You Need to Try One Of The Following :
Remove and re-install Imaging Unit (make sure that Imaging Unit
is locked in place). Turn the printer off, then on.
Replace Imaging Unit (make sure that Imaging Unit is locked in
If problem persists for Error 30, clean the sensor.
If problem persists, check www2.tek.com/merlin/tko and/or
contact Service.
Dec 05, 2008 | Tektronix Phaser 740P Laser Printer
Konica Minolta Fusing Unit Bizhub C252 C250 4038075400 Logo
80 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
