Question about Garden
Gasoline has been left n saw several months. will not start
  • 2,760 Answers
Wow I get this one allot here , if its really really bad then a total carb fuel line replacement is needed to get to 100% again , but if you have the time , a good soak in kerosene of old carb(remove plastic parts) and some new fuel lines sometimes works too
Posted on May 21, 2015
I have a toro 826 snowblower and i cant get the thing to start there is no primmer bulb i dont know if the choke lever goes down to start?
https://www.toro.com/en/homeowner/snow-blowers/power-max-826-oe-37772
Click on parts and manuals then select the year that it was made and then you can download the operators manual.
The most common cause of failure to start is bad gasoline, Gasoline cannot be left in the fuel tank without a stabilizer added to it. It goes bad after about 1 month.
Nov 20, 2016 | Garden
1996 volkswagon jetta will start but dies immediatly ran fine before sat for a few months
It's mad at you for not knowing how to spell Volkswagen.
Also, if you let the car sit for several months, there is a high likelihood that the gasoline has gone bad. Start by draining all old fuel from the vehicle, and replace with new fuel.
If the problem persists, troubleshoot for a fuel delivery problem (such as a clogged fuel filter or stuck fuel pressure regulator).
Jul 23, 2014 | Cars & Trucks
Left gas in my HOMELITE UT10516/16 in. 33cc. chain saw FOR LAST 2 YEARS. WHAT TYPE OF CLEANING WILL I HAVE TO DO TO GET IT BACK IN RUNNING CONDITION?
Get an overhaul kit for your carburetor. Rubber parts need to be changed not simply cleaned. Gasoline handled properly will clean the carb or you can get a spray on product from any auto parts store.
Jun 04, 2014 | Homelite Garden
What kind of gasoline i need?
According to the manual, "use unleaded regular gasoline with a
min. octane value of 91." You need to mix oil into the gasoline at a rate of 50:1 or 2.5 fl ounces of oil to one gallon of gas. If your saw has little power or is very hard to start, it may have been run with straight gas in which case the piston ring or cylinder or both may be damaged enough to warrant replacement.
Feb 02, 2014 | Makita DPC7311 73cc 14Inch Gas Powered...
My chain saw is kicking out alot of smoke, making it quite sluggish, of recent it takes a little longer to start. Having left it a couple of mins. to warm up, it is now conking out when i increase the...
One thing to check is your oil/gasoline mixture. If the gasoline that you used is alcohol enhanced then if you let it sit for a period of time the alcohol evaporates and the mixture changes to more oil than gasoline mixture which makes the exhaust smoke a lot and possibly coats the plug more. Also, regular gasoline that sits in the tank for a long period of time does the same thing.
If your mixture is not at the recommended level,16/1, 40/1 or 60/1 whatever, then the oil will foul the exhaust ports on the saw and back pressure will cause the saw hard to start.
Recommended: take the muffler off of the machine and clean the exhaust ports as much as possible, scraping the built up carbon off. clean the gas tank out removing all of the mixture. Refill the tank with fresh correct mixture. Remove the spark plug and clean or replace being sure that the plug is gapped correctly.
Nov 27, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
Respected Sir, I purchase a Husqvarna's chainsaw last week Model 236- 14". but I cant start it. I read manual carefully, every thing is OK. but Chainsaw can't start yet. So I request you,...
Checklist:
2-cycle oil mixed with FRESH gasoline
Spark plug wire pushed onto spark plug
Chain tight but you can still move it forward with your hand
Switch turned on
Pull the cord a few times, and then let it sit for a few minutes in case it's 'flooded' with fuel
If a new chain saw won't start, it probably has defective spark coil
Chain saws usually don't cause problems fresh out of the box, they stop working if people leave gasoline in the tank for a couple months each time.
Here's what I would do
Empty the tank of gas. Put fresh gas-n-oil into tank (not gas from an old can that was sitting there for a while)
Try starting again.
If no luck, then take it back and exchange for another.
Good luck sir.
Oct 15, 2010 | Husqvarna Garden
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Will not start. Spark ok tried with started fluid
Spark should be blue and snappy with fresh plug gapped at 0.020. Try putting some fresh fuel mix into the plug hole and try to start--it should pop several times. Does the engine seem to have good compression? If not, remove the muffler and check the piston skirt and cylinder wall for severe scoring. If it is, then the engine has probably be run on straight gasoline or poorly pre-mixed fuel/oil. At the very lean fuel/oil ratios ( 50:1) recommended for today's saws, proper premixing of fresh fuel and a modern synthetic oil made for saw use is imperative plus the fuel container should be vigorously shaken just before each filling. If the compression appears good, then check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for any decay or other damage. Make sure the carburetor fasteners are tight. Hope some of this helps!
Jul 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Pole saw won't start
try a small amount of starting fluid in breather and pull small amount
Nov 19, 2008 | Remington 111409 - 01 6" Branch Wizard...
Power source problem
Gasoline-powered chainsaws use a two-cycle engine (requiring mixing of oil and gas). Mobility and power are the main advantages of gas. Disadvantages include the bother and smell of mixing oil and gas, pull cord starting and the additional overall maintenance needed. Electric saws are great for smaller yard chores. They're quieter than their gas-powered cousins, lightweight, easy to start and require less maintenance. However, they have less power than gasoline-powered saws. They also add the bother of dragging a cord around behind you.
Aug 27, 2008 | Remington Polesaw Wizard
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
