Question about Cub Cadet LTX 1050 KW 50" 23HP Kawasaki Lawn Tractor - 13WI93AP010
Ivibrates when i put it in gear
New never used bought last fall mounted deck and it vibrates when i put it in gear
  • Cub Cadet Master
  • 2,963 Answers
If it vibrates when blades are engaged then blade balance or belt alignment is a problem. If without blade but just moving, then a problem with the transmission. Warranty? follow that path.
Posted on Apr 04, 2015
My Audi S3 2009 has had an increase in engine vibration and Revs by itself.
check the engine mounting for damages & transmission mounting.also check the mounting bolt for looseness and tight...
Nov 19, 2015 | Audi Cars & Trucks
My 95 rodeo idles ok but when I put it in gear it starts to vibrate. what could this be?
What is the RPM while in gear? Too low and it will vibrate. Also check for weak/broken motor mounts which will cause a vibration in gear
May 10, 2015 | 1995 Isuzu Rodeo
Too much vibration in reverse gear honda accord 2005
Buy new mounts, used ones are cheap but usually don't last or are worn also.
Dec 31, 2014 | 2005 Honda Accord
Had work done last winter because drive belt kept coming off...Found the two bolts that hold transaxle in place kept falling out, also the plates that bolt over axles were worn/broken...have items rep
I own this model, I have not experienced this issue,something is causing excessive vibration to cause this issue ....a bad belt,misalignment or a sheave that is bent !
Sep 23, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Bought a Toyota Passo from Japan and arrived in Zambia in Sept 2013. When I started the engine, it was vibrating very much. After some checks by mechanics, right side mount was found to be a problem. I...
you need to go to a window repare place and ask them to buy a tube of that black window seal stuff they use to put on windows can't think of the name off hand remove your mounts and fill them with this prouduct take of some of the mount so it will hold the applaction into place lay on flat ground wait a day to dry we do this for street cars so they will last twice as long do to the hard driving hope this helps or you can call a pofromace place and they will sell this also but will pay more good luck
May 03, 2014 | Cars & Trucks
Thumping noise in right wheel when driving 02 kia sedona
Try balancing & rotating the tires. If the sound is gone, problem solved. If it is rotated to a different spot theres the answer
Mar 08, 2017 | 2002 Jeep Grand Cherokee
Have 2002 outback with bad vibration on gear , the engine runs good , I did replaced all mounts , still the same problem, help please.
I concur with anon263. When we replaced driver-side axle with an aftermarket one, the vibration was horrible. Most people around me would not believe that was the cause, but as soon as we replaced it with a Subaru OEM rebuilt axle, the vibration disappeared. Get a new one from Subaru if you can afford it. Here's hoping the rebuilt one will last, although some out there have said that it may cause other problems down the line, most likely just because it won't last as long as a new one. The aftermarket axles, with exception of MW, are off just enough in their designs and spline size to allow harmonic vibration to transfer from the engine to the wheel and then your steering wheel when you are stopped at a stop sign and still in gear. The vibration usually goes away when you put it in neutral or park. In my case, I even thought I detected some strange vibration when driving.
May 30, 2011 | 2002 Subaru Outback
THE KIA SPECTRA AUTOMATIC VIBRATES WHEN ENGINE IS ON AND IDDLE
The first thing to do is make sure that your vehicle is not due for basic maintenance. Plugs,wires,air/fuel filters. After that you can check to make sure your engine and transmission mounts are in good shape. You can do this with the help of a friend. Open the hood and have your buddy put the car in gear while holding the brake. Have your pal put the vehicle in neutral and then into reverse without letting go of the brake. Your engine should not move very much. It is normal for the engine to move maybe about a quarter of an inch but not much more. If the engine jumps and starts vibrating when thrown into gear, You more than likely have bad mounts or a bad mount somewhere. These mounts are made of rubber and fairly simple to replace. Visually inspect them to make sure they are not cracked or broken. If you replace the mounts,make sure to remove and replace them one at a time. You don't want your engine falling out of the car!!!! Good luck and I hope this was helpful.
Jul 17, 2010 | 2001 Kia Spectra
Terrible vibration - 2004 Ford F-150 5.4L
yeah your brakes are sticking and judgeing by the use change out brake pads all arround
Apr 08, 2010 | 2004 Ford F150
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Cub Cadet LTX 1050 KW 50" 23HP Kawasaki Lawn Tractor - 13WI93AP010 Logo
104 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
