My washer will not stop filling with water. I have to stop it and put it on drain and spin to get the water out so it will spin but not agitate. what's wrong?
  • Washing Mach... Master
  • 2,963 Answers
Most likely the selector switch for load size is bad, and or water level sensor is bad. Or water fill valves problem. A temporary fix is to turn off the hot and or cold water supply valves when "full enough". A pain, but a temporary solution. You may want to consider cost to repair vs replacement, possibly with lightly used.
Posted on Apr 04, 2015
SearsTechToo
  • 261 Answers
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Posted on Oct 08, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: washer fills with water then stops, won't agitate or spin
There are two possible causes. The most likely cause is the lid switch, which is supposed to keep you from sticking your hand into the moving basket. On many washers this only keeps the machine from spinning, but on other models it prevents agitating as well. The other possibility is the water level switch, but that usually causes no filling or overfilling if it's bad.
Both parts are available from Sears (www.searspartsdirect.com) and many other online sources. (I normally use the Sears site to find a part number if I don't already know it, then search for that number on Google. It's a great way to find good prices on more costly parts.) There are also a number of sites with detailed information about how to remove the cabinet to get at the parts if you want to try doing it yourself. Replacing these parts is pretty simple if you're comfortable with a screwdriver and have some mechanical ability.
If you'd rather have someone else repair the machine, this would normally be about a 1 hour plus parts charge for an appliance technician. It isn't time for a new washer yet.
Posted on Apr 25, 2009
localwonder
  • 6784 Answers
SOURCE: FILLS WTANK WITH WATER AND DRAINS BUT DOES NOT AGITATE NOR SPINS
Hi. your timer assembly is faulty. it is not initiating the spin and proper wash cycle due to this malfunction. the timer is responsible for the actions and commands. if its defective, it will not carry out the initiations correctly.
CLICK HERE TO BE DIRECTED TO THE PURCHASE PAGE FOR YOU REPLACEMENT TIMER.
Posted on May 23, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
  • 15 Answers
SOURCE: MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12,
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Posted on Sep 11, 2010
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
    Hi, Do you know if the washer spins at all?
    It sounds like the coupler has gone bad.
    Please let me know if it spins at all.
    I can send yyou instructions on changing the coupler.
    Vic
    May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
    Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
    May 17, 2009 | Washing Machines
    Machine doesnot agitate or drain once filled with water
    it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
    Apr 24, 2009 | Washing Machines
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
    Maytag washer
    Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
    Oct 29, 2007 | Maytag PAV2300 Top Load Washer
    Maytag Performa washer Waterlevel/agitator problem
    CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
    Aug 15, 2007 | Maytag Performa PAV2200
    Washing Machines Logo
    32 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
