Question about Technogym Excite 900 Treadmill
How do I install channels? - Technogym Excite 900 Treadmill
Adult roku channels
    Adult Channels:
    Adult Channels additionally called private Channels are not showed in the Roku channel store for all average Roku users.
    Such channels are included physically.
    Adding the Adult Channels:
  1. Open the main screen by pressing the home button
  2. Select Streaming channels from channel store
  3. At top of the Channel Store is a list of new and well-known categories to explore.
  4. By using the search function, the user can easily browse their favorite channel.
  5. On the remote, Press Forward button to navigate to next page.
  6. If you want to know more details about the selected channel, Press ok on your remote
  7. If the channel is free, then you can install the channel directly on your Roku device.
  8. If the channel is paid, then you select to buy the option to purchase that channel and then install on your device.
  9. To include a channel by code you should login into your Roku client account.
  10. After that, within 24 hours the activated channel will appear on your Roku player's home screen and to "My Channels" in the Roku Channel Store.
Mar 28, 2017 | Roku Televison & Video
Installing channels
Go to the initial setup for your TV which should be selectable using your new remote control.. Select the option to search for active channels in your area.
Jan 25, 2014 | Televison & Video
E8 Error
Hello here is the homepage:
http://www.asrock.com/mb/Intel/X58%20Extreme6/?cat=Manual
I think you have a ram problem:
1. Please install the memory module into the white slot (DDR3_A1,
DDR3_B1 or DDR3_C1) for the first priority.
2. Due to Intel CPU spec definition, the system will not boot if only
one DIMM is installed into DDR3_A2, DDR3_B2 or DDR3_C2 slot.
3. Due to Intel CPU spec definition, XMP DIMMs and DDR3 2000/
1866/1600 are supported for one DIMM per channel only.
4. You may install varying memory sizes in Channel A, Channel B and
Channel C. The system maps the total size of the lower-sized
channel for the dual-channel or triple-channel configuration. Any
excess memory from the higher-sized channel is then mapped for
single-channel operation.
5. It is not allowed to install a DDR or DDR2 memory module into
DDR3 slot; otherwise, this motherboard and DIMM may be
damaged.
Try only with one module, in the white slot.
Hope this will help you.
Jan 30, 2013 | Asrock X58 EXTREME6 LGA 1366 Intel X58...
How do I get local channels when my Roku is connected to my TV
The roku is a one way streaming device and cannot see channels that your cable tv can see. It streams online content to your tv.
However if you live in a major metropolitan area 1 or more of your local channels may be available online, you can set those up in your private channels area then searching for local channels in your area to add as private channels.
Jan 27, 2013 | Computers & Internet
Problems with installing digital channels on a Prosonic tv model: PS22DVD904
If you dont have a built in tuner you will have to buy a set top box.there are no analog channels anymore.
Aug 17, 2012 | Televison & Video
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
How to install backup launcher for Wii LU64 and up models?
Hi - The Homebrew channel can not be installed on ANY Wii. A lot has happened since the softmod came out and it now takes about 10 mins to install the homebrew channel and Loader. Here's a great guide on how to install the Homebrew Channel and a Loader on any Wii:
http://www.wiilovemario.com/The-most-up-to-date-Wii-Homebrew-and-Backup-tutorials-known-to-mankind
Jun 25, 2009 | Sony Playstation 3 (PS3) Console
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Technogym Excite 900 Treadmill Logo
41 people viewed this question
Top Technogym Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Technogym Exercise and Fitnes Expert? Answer questions, earn points and help others
