Question about Keurig K45 Elite Brewer
All go my lights flash at the same time when unit is plugged in. It also sounds as if it is heating. Unplugging and plugging back in do not change anything. Pressing a button changes nothing as well.
  • 60 Answers
SOURCE: After filling with water, plugging in, and
Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
tbreeze47
  • 3083 Answers
SOURCE: the machine says, not ready
I wrote this before I found the video at the end:
You should contact Keurig about this problem, because whatever the problem is, it's going to require disassembly and troubleshooting the problem. A sensor or switch could be faulty, a valve dirty/stuck/broken, the heating element open, or you could have a faulty control board. Sometimes it's something as simple as an oxidized contact on switches and wires, and simply disconnecting and reconnecting them can solve the problem. They don't make disassembly easy on most things since they really don't want you to fix it, and that's the rub. Sometimes they use security torq head screws to discourage home repair. Here's the contact number for them if you need parts or help, taken from wholelattelove.com
nophoto.jpg Carol Alix
button_small_question.gifAsk the Experts button_q.gifQuestion Where can I get Keurig Parts?
button_a.gifAnswer All parts, tech advice, and repairs go directly through Keurig. to reach them, please dial 1-866-901-2739.
Actually, I had written this answer before I found this video:
http://www.youtube.com/watch?v=xjWIQpttTc8&feature=related
Hope this helps you. There are more videos on that page which address different problems, and might be useful.
Good luck, hope this helped, and thanks for using FixYa.
Posted on Sep 17, 2010
e-Guru
  • 3917 Answers
SOURCE: Pressing a "Brew" button returns
Hi
This is a known problem with the B50 which Keurig will acknowledge considering your problem. Some users have suggested trying to clean the check valve just inside the water outlet but the best solution is probably to call customer support, complain like crazy, and take the discount on a new machine that they will offer you. Apparently, this problem occurs much more often with the B50 than with more recent models. You can contact Keurig at 1-866-901-2739 or Keurig.com
However if you are out of warranty. They will give a discount on a new unit if you want considering the fault in your machine.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 19, 2011
hubbardb
  • 159 Answers
SOURCE: Keurig Elite B40 Coffee Maker after "add water" and "heat" and "power" lights start flashing.
Thermostat has failed replace or repair
Hope this helps
Posted on Aug 21, 2012
SOURCE: Keurig Elite B40 not responding after "add water" and "heat" and "power" lights start flashing
Unplug the unit to reset it. That will give you a short term solution. I had the same problem, my machine is only 4 months old. They sent me a new one. I was told that there is no way to fix the problem for good. The unit is defective. Luckily I registered my machine right after I got it, and I kept my receipt They sent me out a new one, free of charge! It took about a week to get it..
Posted on Aug 27, 2012
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
When I push the start button, why does it just click and lights flash a few times than nothing?
Try rebooting the electronics by unplugging the unit for 30 seconds and plugging it back in after that. Does that reset the unit for you?
Dec 25, 2015 | Washing Machines
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
TV will not turn on. I press power and it sounds like it's coming on and then clicks and the stand by light flashes 7 times. Have already tried unplugging and then plugging back in after a minute
When I called a tv repair company the rep said this usually indicates that the "lamp" for this model needs to be replaced. Since he TV is so heavy he suggested that I access the trap door in back of the console and detach the "lamp" myself and bring the lamp to his shop for replacement. Approximate cost for the lamp is $200.00. Wish me luck.
Dec 01, 2011 | Sony FD Trinitron KD-34XS955 34" TV
Pressed power, heard the unit turn on, heard the tv show sound for a moment then it went into standby mode and the red light flashes six times, then pauses, six times then pauses, over and over and over. ...
Either your power supply is bad and needs replaced, or their is other circuitry issues. Bets to have a trained technician look at this and give you a quote for repair, it might be cheaper in the long run to replace the set.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I can't turn the monitor on. The light continuosly flashes
I would go ahead and get a new monitor. It sounds to me as if the button is broken were it connects on the inside
Feb 23, 2010 | Acer Value Line AL1717B Monitor
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Won't start
is the light going off when the door is closed, and on when opened??? sounds as if you having ansd issue withthe door switch, notthinkin the door is closed, try manually pushing the buton in, you should hear it "click", if it doesnt, i would unplug hte unit, nad witha screrwdriver you can pry the switch out from the side of switch. Dont ask me why buit for somereason afetr removing from the unit, it then will"click". somply prerss back inot place.Never actually had to replace teh switch, perhaps it gets stuck!
Jan 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Flashing lights
Hi, I work on these on a regular basis and have seen the problem many times. Almost every single time it's caused by a faulty fuser (fixing) unit. They are fairly easy to replace but they run in the 2-300$ range in cost. Good luck.
Aug 29, 2007 | Brother HL 5250DN Laser Printer
Keurig K45 Elite Brewer Logo
636 people viewed this question
Top Keurig Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Keurig Kitchen Appliances - Other Expert? Answer questions, earn points and help others
