Question about Kitchen Appliances - Others
I need a new spice grinding insert as mine has fallen apart
This is the finer grinding lid for the ZX809-1
3 Suggested Answers
SOURCE: how to adjust new baratza maestro plus
I, just adjusted the the solis 167; first remove the Bean container by turning counter clockwise and the pull straight up) then remove the timer dialer (time/quantity control), then remove the cover by lifting the locking tabs (2 slots each side) with a flat screw driver. Once you removed the cover. Pull straight up the the white ring with the metal cup. Now you see a dark ring which is clicked on the with unit. When you look under the ring you an see little holes all along the white unit (that's important because you need to mark your old position). After marking the thr ring on the white unit, pull off the the dark ring by slowly pulling the ring outwards just on 2 places on the ring where there an small hole in the ring (there are 4 holes). When you turn the ring you will see 2 nobs, now place back the ring with the nobs 2 places further(clockwise) than the old position. You have just adjusted the grinding control! Place back all parts in reversed order. To place back the Bean container you must be aware that there are 2 black nobs in the machine and 2(different sizes!) on the container, they must be placed in a cross.
I trust you will hav succes. Don't turn to far at once because you have now modified the machine and this could damage it! I will assume no responsibillity for damages! Masta NL
Posted on Apr 02, 2010
SOURCE: Casio G-2000, can I buy a new black resin bezel as
I'am putting two g-2000 on ebay spares or repair
Posted on Jan 09, 2011
It is not self cleaning after making espresso. The coffee grounds are crumbling and dropping into the machine rather than as a tablet into the waist basket. Any idea what I need to do?
Try using a finer grind. Remember to adjust grind only when it is grinding. This being the case you may need to do a second brew to test new setting. Mine is set to near finest and I always use fresh beans.
Sep 13, 2015 | DeLonghi Magnifica Coffee Makers &...
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
I need to replace the switch that starts the washer when it's closed.The switch has fallen apart.Where I can get a switch and what is the approximate cost. The switch is 0.5 HP ,125v and 60 Hz.The...
I bypassed mine , got a connector and hooked the wires together. Runs with lid up or down, just remember to keep children away from washer and don not reach into tub while running.
May 23, 2011 | Kenmore Washing Machines
My Solis Maestro takes a long time to grind and no longer grinds for espresso. How do you remove the burrs to clean them? Should they be replaces?
HI
Yes the burrs will wear out. They can be replaced. To remove the outer burr. Twist the bean hopper counterclockwise until it stops. Lift the bean hopper out. There is a cream colored ring with 2 tabs that will lift out holding the outer burr. To get the inner cone burr out is a little more difficult. We use a vice grip and grab the burr, and lock the pliers to it. Then with a quick movement clockwise on the pliers, you loosen it. Then clockwise unscrew the burr. When you install the new burr, it truns on counter clockwise until it stops. Insert the new outer burr. Push down so the tabs will lock in. Install the bean hopper into the correct slots ( 1 large tab and 1 small tab). Twist clockwise to turn on and test. Remember it must be grinding to turn to a finer grind but can be turned to a coarser grind any time.
Jan 24, 2011 | Solis Maestro Electric Burr Grinder
The coffee comes out in little logs or clumps. The coffee is weak- no crema.
HI
There are 2 things that can cause this. Either the burrs are bad and need replacing or you grinder is out of adjustment and you need to turn to a finer grind. If you have taken it apart, you are not adjusted close enough so your burrs can't grind fine enough. Readjust the burrs closer together.
Oct 11, 2009 | Rancilio Rocky Electric Burr Grinder
Don't know how to use Mr.Coffee IDS57 coffee grinder
Typically you load in the beans, replace the cover and then either press down on the entire cover or the black knob on the front of the cover. I would hold the lid down with your other hand just to be safe. Grind for about 4-6 seconds depending on how strong you like your coffee (the longer you grind the finer the coffee will be...this means STRONGER)
Jun 09, 2009 | Mr. Coffee IDS57 / IDS55 Electric Blades...
Solis Palazzo Bean Grinding
That one with number on is finer or coarser grinding beans, the other one is for how much gram it would grind. + means more gram.
I hope this will help you.
Apr 28, 2008 | Solis Palazzo Espresso Machine
Opal telling me beans lid is not on when it is ?
hi
i work on schaerer machines. on the back of the lid there are two plastic spikes that make contact with in the machine, when you lift the lid it breaks contact so when you select your product you dont put your hand near the grinder. order a new lid or write back and ill tell you how to jam it open. If you want?
Jan 05, 2008 | Schaerer Opal Espresso Machine
Kitchen Appliances - Others Logo
342 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
