Question about Brookstone Victoria Tunewriter III USB Recording Turntable
Why won't the door shut on my cassette player shut with a cassette in itwhy can't i get an answer to my question
    Novelist:
    Habit-Forming:
  • 97 Answers
I'm sorry, but it seems you may have a product that no one has any experience with.
But just to help in any way I can I will suggest reading your operational manual to make sure your inserting the tape correctly.
Or maybe your tape has reach the end of the roll and is automatically ejecting it?
Check that all other applicable settings are correct for insertion of a cassette tape.
Does your device allow a "recorded tape" to be played? Or does it only accept "recordable tapes" to be recorded? I do recall that cassettes have a way of being identified by a player as to whether or not it is a "recordable" or a "non-recordable" tape.
I probably wasn't the best help you could have got here on fixya, but I have exhausted my advise to you, as general as it may be.
If my advise wasn't the solution, please be patient or reword your question to attract the experts in the field of cassette recorders or music recording equipment. Different headings will be directed to the answering panels that are associated with answering those type of questions.
Good luck
Posted on Apr 04, 2015
Cassette door will not stay shut
yep thats the camera telling you that its broken or that the tape is damaged
Nov 01, 2014 | Samsung VP-D103i Mini DV Digital Camcorder
I have the Victoria tunewritter GDI-TW4CD. Sadly when I push play after record, wheile recording vinyl to CD I get backwards 344 error? help please
I don't have an answer to your question but at least your cassette player door closes once you insert a cassette mine does not
Nov 02, 2013 | Brookstone Victoria Tunewriter III USB...
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Panasonic cassette player no auto shut off
try google. i looked up my walkman and found the belt was bad.
Apr 27, 2010 | Sony Walkman WM-FX141 Personal Cassette...
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Brookstone Victoria Tunewriter III USB Recording Turntable Logo
106 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
