Question about Victoria GDI-TW4CD - Classic Gdi-tw4cd Tunewriter Iv Retro
Door of cassette deck will not close with cassette in it
How to fix sony camcorder with tape deck that won't close. camcorder squeals and ejects tape.
bit late...but. STOP ASAP! by removing the battery, after removing battery, wait 20 seconds, re-fit battery & CLOSE the cassette door.
then wait 10 seconds, slap the closed door twice quite firmly. then open, if it opens, discard that cassette tape, clean the players head using cleaning tape.
use new cassette tape.
Jun 30, 2015 | Sony Video Cameras
Why won't the door to my cassette deck on Victoria tunewriter III close once I have inserted a cassette?
I'm not familiar with this unit but the frequent cause of this problem is that the record/playback head is not retracted from previous use. Frequently caused by drive belt problems - loose, broken or off track. Try running the drive with the door closed and no cassette. This seldom is a problem that the owner can fix. Professional service is recommended.
Apr 04, 2015 | Audio Players & Recorders
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
I have a sony cassette deck tc fx44. If I try to insert a cassette am unable to close the door. The door closes just fine without a cassette
Sometimes the tape sensors or record sensor gets bent or out of place so the door wont shut. Look for something like that.
Mar 30, 2013 | Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
The door those not close when I put a cassette in it. I closes normaly without a tape. Does anybody know this problem ?
alot of cassette tape deck doors actually come off, they clip onto the inner door assembly, if the outer part isnt clipped on correctly, it may shut without a tape, but not with a tape inserted, try to see if the outer door is clipped on there correctly, jim d
May 07, 2011 | Audio Players & Recorders
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
I can't eject the cassettes from the deck - both seem to be stuck. How do I fix this problem?
only one way. I did this before. take your fingernails, stick them in the top of the door, and pull. want to use it again, put tape to hold door close.
May 11, 2010 | Sony TC-KA3ES Dual Cassette Deck
Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Dec 25, 2007 | Audio Players & Recorders
Victoria GDI-TW4CD - Classic Gdi-tw4cd Tunewriter Iv Retro Logo
814 people viewed this question
Top Victoria Car Audio & Video Experts
xxxxxx xxx
Are you a Victoria Car Audio and Video Expert? Answer questions, earn points and help others
