Question about Sony GDM-400PS 19" CRT Monitor
Distorted photos on my widescreen
I have a new Dell 19" widescreen monitor that I use with my new Dell Computer. However, some of my photos are distorted on this new widescreen (mostly the photos of people). What adjustments for a widescreen do I need to make?
0 characters
1 Points
Is this computer monitor compatible with a Dell computer?
If your computer has a HDMI out port or a VGA out port it will work you may need drivers but it probably came with a driver cd if not just go to and search for ""Hannspree 19" Drivers"". A VGA port is blue with 3 lines of 5 holes and looks like a triangle with the top cut off.
Aug 04, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
My monitor suddenly has become distorted. It appears scrunched horizontally, from both the right and left sides. The whole monitor image is visible, but it is distorted. I have checked the cables, reset...
Try connecting the monitor to a different computer (desktop/laptop).
If the symptoms persist, it's time to responsibly recycle the CRT, and to replace it with a 19-inch LCD monitor.
Sep 30, 2010 | Dell E771a 17" CRT Monitor
I have changed to an Acer 19in wide screen monitor, my photo albums appear as wide screen pics
You need to set the PC video resolution to 1440 x900 @60Hz which is the native resolution of this monitor.
Mar 17, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
MY monitor is very distorted.
Try disconnecting and reconnecting the cables. Sometimes this is a cable connection issue.
Mar 20, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
My photographs are distorted on my widescreen, how do I rectify?
go into the settings menu for the monitor, properties settings display, and change the resolution to the native resoultion for your monitor, iyt sounds like you arend running it at the proper resolution, also run the driver that came with or is on the website that is associated with this specific monitor, it sounds like it was never set up right
Jan 07, 2009 | LG 22" Widescreen Flat Panel LCD Monitor
Got a dell computer wont pick up westinghouse moniter
Use a different monitor to test and set up the PC, try lowering down resolution settings, and test also the video cable.
Try also changing the monitor input channel, just in case this is set on a different connection input.
Dec 25, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
No XP driver for Hannspree New york 19 inch monitor
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Nov 16, 2008 | Hannspree HANNS-G 19" Widescreen Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Jun 09, 2008 | Acer AL1916W 19" LCD Monitor
Sony GDM-400PS 19" CRT Monitor Logo
806 people viewed this question
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
