Question about Crest Audio Audio Players & Recorders
Voltage of crest audio 10001 trasformer power amplifier
Can not infor no where fred
  • James Kovacs
    James Kovacs Aug 04, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
3 Suggested Answers
StuartB
  • 807 Answers
SOURCE: Parts for Technics SE A900S Audio Power Amplifier
Here ya go.
http://www.vancebaldwin.com/products/?MSCAN7062
Posted on Mar 13, 2008
  • 5370 Answers
SOURCE: when i turn on my crest audio 8001 it stay in
The power transformer is getting short and overheated causing it to go in thermal protection mode.Also if the amplifier gets overladed by its connection, it goes to thermal mode.
The problems i have seen most often in Crest amplifiers is bad capacitors. They look fine from the outside but pull one out of circuit and measure it and there bad. These are the small electrolytic types. there are 2 sets of solid white wires from each output module to the output relays. Inject a a signal into the amp and take a look at the signal on those white wires. If the signal looks clean with minimal DC offset then you have bad caps causing it to stay in thermal protect. A very common crest amplifier problem.
Check in between the heatsink's. These amps have a tendency for those heatsinks to arc across the sinks. There are only 2 thin rails that hold the modules and rough tour duty service can cause those rails to bend and the sinks to touch and arc. Even a bug getting between the sinks can cause them to arc if the amp is running hard!
Also look for open resistors. This are possibilities, that can cause the amplifier to remain in thermal protect mode.
------------- This should help.Thanks.Helpmech.
Posted on May 31, 2011
What is the voltage of transformer of crest audio vs450
Power Supply (factory configured): 100V-240V, 50-60Hz
You should only need a standard power cord (like the one that fits the back of a computer).
CREST AUDIO VS450 Specifications Page 2
Feb 04, 2015 | In Store Used Used Crest Audio Vs450
Crest audio ca12
Dust in the unit - clean with Canned air like a computer.
or Delamination on the printed circuit board.
Don't forget to clean all contacts on the backside of the unit!
If cleaning doesn't work - head to the local Crest "AUTHORIZED" Service Center.
Mar 24, 2014 | Crest Audio Audio Players & Recorders
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
Smoke comes out from the switch and wont turn on ... there 2 amps make of ca9 and ca6 wondering if you guys can help
This is a very easy cheap fix, but since this thread is pretty old first make contact to help you out with this issue, common on CA series power amplifiers of Crest Audio.
Aug 12, 2011 | Crest Audio CA 9 2Channel Amplifier
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Why my crest audio ca6 has the lights clip signal
disconnect you load (speakers) power amp up. If this fault persists there might be a problemm with the amp
Apr 21, 2010 | Crest Audio CA9 Car Audio Amplifier
Every time I turn the amp on it shuts its self off.
disconnect all speakers and test if the problem corrected you will have a problem in your speakers(either wire or speaker itself)-try to connect the speakers one by one until you find the bad one and change it--if all above does not work send your amp to service center near you
Mar 30, 2009 | Crest Audio CPX-900 Amplifier
No power
These amps are very compact and are not the easiest to work on. If you are not experienced at repair, I would not recommend you start here. Where are you located?
Dan
Jan 13, 2009 | Crest Audio CPX-900 Amplifier
113 people viewed this question
Top Crest Audio Audio Players & Recorders Experts
Owen Barnes
Gregg Errera
Gregg Errera
Level 1 Expert
spacil
spacil
Level 1 Expert
Are you a Crest Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
