Question about Air Tools & Compressors
I need a new start capacitor, and cannot find one that is the right dimensions
    Master:
  • 459 Answers
If it has the correct electrical rating but can't find the correct physical size, build it a new capacitor housing from sheet metal or similar
Posted on Apr 05, 2015
Can faulty Capacitors cause this PC to just start DRAGGING slow, even on a FRESH install?
It most assuredly can, and a fresh install will not help, if that is the problem. What makes you think it is faulty capacitors?
Oct 16, 2016 | Dell Dimension 3000 PC Desktop
Where can I purchase this capacitor? I was told that if I can not find this exact capacitor I can combine two small capacitor to get 125 uf is this true?
Is this a motor start capacitor? If so, you can get from the following:
http://www.amazon.com/HL008500AV-Campbell-Hausfeld-Capacitor-250VAC/dp/B0078PAR3U/ref=sr_1_1?ie=UTF8&qid=1427545862&sr=8-1&keywords=cbb60+120+uf+capacitor
You did not specify if this is a leaded or screw terminal, what it is used for, or any of the dimensions. If you are unsure, take the capacitor to an electronics repair store and ask them to source a replacement.
In this instance, I would not suggest trying to connect two capacitors in parallel to replace it. There should be replacements available.
Mar 28, 2015 | Miscellaneous
My Dometic RM 2612 refrigerator makes a continuous clicking or like a knocking sound right away when you turn the ( ON ) button to on and start up refrigerator ... it does this right away and not every few...
What you are hearing is that the compressor is trying to start but can't..... And you could be right the compressor could be bad and the start capacitor could also be bad... I would try a new start capacitor or have the old one checked to make sure it is only the capacitor before I would condemn the compressor..... If you can get your hands on a 3 in 1 start capacitor you can try and see if the compressor will start also put an amp probe clamp meter to check if it drawing close to LRA on the name plate of the compressor..if it is and you have a good start capacitor then the Compressor rotor is locked up and you will need to replace the compressor or get a new or different refrigerator....
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician or HVAC tech to advise what work is needed.
Before you do any work yourself,
on electrical circuits, equipment or appliances,
always use a test meter to ensure the circuit is, in fact, de-energized.
IF YOU ARE NOT ALREADY SURE YOU CAN DO THIS JOB
SAFELY AND COMPETENTLY
REFER THIS WORK TO QUALIFIED PROFESSIONALS.
Mar 22, 2011 | Refrigerators
I have a ceiling mount Encon fan/light. While trouble shooting, I found that the motor capacitor had "opened", and the sides of which had blown outward. I want to get a new capacitor. The model is:...
You don't need those particular models of capacitors, all capacitors with those characteristics (.2 and .4 microfarad at at least 200 volts) will do. You can find them at all hobby shops - just remove them and ask for a similar one.
Jul 04, 2010 | Encon Industries Dryers
I put a new harddrive in my dell dimension 3000. and once the OS was done and windows started up i could not adjust the resolution or go on the enternet. also no sound? what is am doing wrong
You need to get ethernet,graphics and audio drivers
to get internet , screen ,sound to work!
Get the right drivers and it will work!
Please vote!
May 13, 2010 | Dell Dimension 3000 PC Desktop
Won't turn on only blinking yellow light
The blinking yellow light on the power button is almost always a power supply failure of some kind. You should try disconnecting the PC from the wall and letting it sit for 10 minutes to let all the power in the capacitors drain. This will do a mini-reset on the power supply. Plug the power back in and then try it again. If that doesn't work, find the 110/220V red switch on the power supply, unplug the power from the wall, flip the switch a few times, make sure it lands back on 110, then connect the power and try turning it on again. If those don't work, you'll need to replace the power supply unit.
Aug 04, 2009 | Dell Dimension 4700 PC Desktop
Orange light blinks
I would try another power supply, but first check the capacitors on the motherboard. If you get another Power Supply, Use one that has the same or greater output watts. I keep several old ones around for this purpose. If that does not solve it then you may have a failed motherboard. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Be sure to look under the fan shroud also. The dead giveaway will be the fact that you are not getting anything after you change the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not always mean no power, just not enough to run the computer. IF you have recently made any hardware changes I would start there first, but it sounds like a bad PSU or MOBO.
Jun 12, 2009 | Dell Dimension 5150C (DIM515CMIN) PC...
Fan runs, compressor tries to start then kicks out on overload.
i am not familar with this model number..
1. are you using the right type of capacitor. you need a "start" capacitor not a run capitor. make sure that capacitor is the proper size.
2. have you tried a hard start kit?
3. is their oil in the new compressor?
4. was the old compressor for r-22 or 410a?
5. is the new compressor for the proper refrigerant?
6. is there refrigerant in the system?
7. is it wired right?
8. is this a heat pump? if so is your reversing valve operationing properly?
9. was the old compressor a mechanical or electrical failure?
if electrical did you install a new filter drier?
10. just because the new compressor is new does not mean it is good
11. do you have the proper voltage?
good luck
hvac teacher
Mar 23, 2009 | Goodman GMS90703BXA Heater
Craftsman compressor motor/capacitor problem?
I had the same tripped breaker problem with a similar Sears model 919.195060 (25 gal) and luckily I had access to another, almost identical sears compressor to swap parts to diagnosis it. It turned out to be the run capacitor, but from what I was finding in my on-line research, it could have been a bad winding on the motor or the start capacitor just as easily. If your resistor is outside of the capacitor, just cut the wire right at the capacitor and add flag termnals Mine had 3 wires coming out of the capacitor (not the normal terminal cap style), and two of them were basically just tied together (same color). I didn't have an external resistor. I bought a GE 97F9614 run capacitor (40 mf, 370vac) and other than having to cut out a bit of the plastic on the mounting bracket and buying "flag" style 1/4" terinals from radioshack, it fit and worked perfectly. It seems if GE is the only one that has the right dimensions (1.75dia x 3.88 long, not including the terminals. That capacitor cost $27.50 with tax at a local electric motor shop. Sears doesn't even have any info on the motor parts, like capacitor - they want to sell you a new motor for almost as much as a new whole compressor. I ended up looking at parts forr the motor on a Devilbliss (that's what the 919 means on the model number, that it's made by Devilbliss), but it was not an easy way to go and really didn't help that much). The easier/normal way of matching capacitors is to measure the case dimensions carefully and match up the voltage and uf (or mf) specs,
Oct 27, 2008 | Air Tools & Compressors
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Air Tools & Compressors Logo
129 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
