Question about Music
Circuit board repair
Everything works except the chorus function is not working. I would like a repair manual with circuit board prints and schematic diagrams.
    Top Expert:
  • Music Master
  • 3,107 Answers
You don't tell us what make and model you need help with
Posted on Apr 05, 2015
No sound from dean bass
Check battery. There is a small circuit board that is not attached to anything except a few very fine wires. These came loose on mine and no schematic is available. I trashed mine and bought a Fender Jazz. sorry
Jan 20, 2014 | Dean Edge 4 Bass Guitar
Yamaha pf85 14 keys not working & two of the three circuit boards look damaged.
The PF-85 action works by having the hammers strike the contact strip, which in turn connects the trace patterns on the circuit boards you're looking at together.
Any dirt between the contact strip and the circuit board will cause the keys to not function correctly. You can remove dirt with rubbing alcohol (iso-propanol) and a cotton swab. The only thing on these boards is traces, contacts, and diodes so they are safe to handle...just don't get finger prints on the contacts.
You should also make sure that the white wires are plugged in all the way on the back of these boards. A loose connection will cause the problem you've described. As would missing screws!
Sep 13, 2012 | Yamaha P-85 Electronic Piano
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Hi, I have just bought a casio CT-670 keyboard ( very old I know). It was not working when I bought it. I have taken the back off and all looks well except for the power wires. They are attached to DC 9V...
This service manual should be close to your unit... it is a CRK671:
http://elektrotanya.com/casio_ctk671_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links.
Power input schematic is on page 10, lower right corner. They appear to "or" in the batteries with the adapter if adapter is used. Look for the diodes and also the bifilar power inout filter.
Jul 28, 2011 | Casio Music
Line 6 Toneport KB37 Phones output has lost one channel after being dropped. Need the circuit for the phones preamp so that I can replace/or repair the preamp. Is there a service manual or wiring diagram...
You will probably have to go to Line 6 to get a schematic... HOWEVER, it is likely a visual inspection will reveal the failure due to dropping. Look first for bad solder at the headphone jack. Next under a bright light look for circuit board cracks. This is going to be surface mounted parts and unless you have an equiped shop, it is not likely you can successfully work on the board if it is not a visible problem.
Jul 04, 2011 | Line 6 Tone Port UX2
Peavey classic chorus 212 buzzes, sguelches, squeals...
There MAY be a circuit trace on a board that is cracked OR a poor soldered connection. It is vibration sensitive as you have found. Changing a switch vibrates the unit.
Depending on what you have connected, this could even ba a bad input jack.
The unit needs to be serviced. You could open it and see if there is something obvious.
Jan 13, 2010 | Peavey Jsx Mini Colossal Guitar Amplifier
Got a 5000 euro power the output module has gone i think as it turns of after 2 seconds can you get a replacement part copy
I had to repair mine. An arc had occured between circuit traces and a heatsink in the power amp and that took out a half dozen transistors, a switching regulator chip, two power resistors, diodes. The parts are all available BUT you must be very careful to weed out ALL the bad ones.
AFTER repair, put a 150 wat light bulb in series when powering up to avoid damage IF there still is a bad component in the circuit.
After cutting out the damaged board and replacing the parts it is all working again.
I had to trace out some of the circuit to troubleshoot as Behringer won't give out schematics.
The amplifier in this is a class "D" switching type. Be very careful of running the unit if the speakers are not connected.
Nov 04, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Yamaha PSR keyboard won't power up
Unfortunately, I only have schematics for PSS-560 and PSS-570. If I remember correctly,with the parts side facing up, there should be a parts orientation printed on the circuit board. It will look like 2 black bars side by side with one of the black bars thicker than the other. If you got an exact replacement with the correct pin out the metal piece on the part that the black piece is mounted to with the 3 pins facing down towards the parts side of the circuit board should line put with the black bar lines on the circuit board. I hope this makes sense. Please get back to me. I had one of these keyboards laying around in my parts bin but stripped it because all the keys were broken and as they come in one strip asnd have to be ordered specially, I didn't bother keeping it. I may still have the circuit board somewhere.
Apr 15, 2009 | Yamaha Music
Music Logo
44 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
