Question about Camping, Backpacking & Hiking
I have a 2,000,000 Vector126 spotlight and can't find the battery for it. Can you help me?
  • 1,631 Answers
How to put battery in my spotlight need video
go to:youtube ; replace battery in spotlight, It depends on what kind of spotlights you you have. there are LED, REGULAR and VECTOR DUAL LAMP, ETC...
Aug 27, 2017 | Camping, Backpacking & Hiking
Could really use your help repairing a WorkForce SportSpot WKF124HD. The WorkForce SportSpot 1,000,000 candle model WKF124HD Locking Trigger MOMENTARY SWITCH for on / off light control has failed.
You can try to find the O.E.M. part, take one from an old junked light, or find a generic switch from the hardware store and make it work. You diagnosed the problem already. You could replace it with a regular (DC) switch if you normally "lock" it on most of the time.
Miniature Pushbutton Switches
You might just consider replacing it, as it seems there is risk for fire with this model.
1 000 000 Candlelight Spotlight fire
Feb 02, 2016 | Vector Cars & Trucks
Coleman 530 Lumens Spotlight needs a need battery FIFUTEC FP 1228, 12V 2.8Ah. Where can I find the right size?
Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
Mar 05, 2014 | Coleman LED Rechargeable Spotlight
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
I have a 80 series landcruiser done the spotlights but thay keep blowing my head light fuse the wires are 2 times bigger than the ipf kit
The fuse has a lower AMP that is why it is blown every time you switch on the spotlights. In order for the fuse not to be blown, my suggestion is try the direct connection on the spotlights. Connect the spotlight directly to the battery. Just put a switch on it. If you want to use the spotlights, just press the switch.
Jun 26, 2010 | Cars & Trucks
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Jun 10, 2010 | Vector 1 Million Rechargeable Spotlight
Will not hold a charge...Looking for a replacement battery? Any Ideas?
http://cgi.ebay.com/VECTOR-1-MILLION-CANDLE-POWER-SPOTLIGHT-FLUORESCENT-NEW_W0QQitemZ220469526499QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335501ffe3&_trksid=p3286.c0.m14
Aug 31, 2009 | Vector 1 Million Rechargeable Spotlight
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
Camping, Backpacking & Hiking Logo
323 people viewed this question
Top Camping, Backpacking & Hiking Experts
weirdtop
Tom Chichester
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
