Question about Dishwashers
How do I stop the noise in my reverse osmosis
It sounds like water running
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Take it apart and clean everything.
Posted on Apr 05, 2015
My culligan reverse osmosis system is making a "honking" type noise. I can feel the blue lines pulse each time it honks, every 10 seconds. What can I do to stop the noise?
There is a problem with the automatic shutoff. There may be carbon fines or debris in it. When the shutoff is trying to close it will have a chirping or light honking noise. Try running all the water out of the tank Make sure you clean and sanitize the filter housings when changing filters.
Here is a link for Culligan RO manuals.
http://www.freshwatersystems.com/t-manuals.aspx
RJ
Jun 11, 2011 | Culligan Sediment Water Filter
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Kitchen drain constantly drains (Noisy)
If your heraring a ticking noise, it will most likely be the begining of a clog , usually if its an older home ,with garbage disposer,are the most common.Hope This helps!
Apr 03, 2009 | Plumbing
The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Aug 19, 2008 | Admiral 26 cu. ft. Side-By-Side...
Dishwashers Logo
57 people viewed this question
Top Dishwashers Experts
Owen Barnes
