When my tv on it turn on and automaticaly turn of before come the screen.it HOT blow.then i replace new one.it also blow.what is reason it.i checked primary winding in LOT meter.reding was 0.8 ohom
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 04, 2015
Where's the fuse on flat-screen western tv
There are few technology tragedies as sad as a dead big-screen TV. Sharp-eyed readers may recall that I suffered just such a misfortune in November 2010, when my nearly 5-year-old 42-inch set dropped dead unexpectedly. At the time, I described the scene as follows:
After attempting to revive the set by turning it off and on, unplugging and reconnecting the power plug, and other basic troubleshooting, I had to face the hard conclusion that my television was dead.From there, I detailed the research, purchase, and installation process for my new plasma, a 50-inch Samsung 3DTV. That new set has been great, even if the 3D highlight so far has been the 3D Yule Log special on one of Time Warner's on-demand channels. For a complete accounting of how I chose my new TV, you can read the full blow by blow here. I'm sure I could have done some additional troubleshooting on the dead TV at the time, but a good reason to upgrade to a new flat-screen doesn't come along every day, and I was probably looking for an excuse.
Mar 16, 2017 | Televison & Video
My Mac book has a roaming sound and it is getting very hot and it turns off automaticaly
You have the fans clogged or damaged and that's the reason the Mac come hot and for protection turn off because if no you will fry the motherboard.
Mar 28, 2013 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
PLAYSTATION3 TURNS ON ,AFTER ABOUT 1MIN. TV SCREEN SAYS HOT ,
Ok sounds to be ur fan not working,,or clogged,,ok check the system vents,,if dust in there,,blow out with air in a can,,if anything aircompresser,,with blow tip,,or u blow in it,,could fix it,,,try and see,,if not see if u hear ur ps3 fan running,,,could be bad,,easy fix,,,good luck
Feb 09, 2013 | Sony Playstation 3 (PS3) Console
DOES NOT TURN ON
Hello
Open your TV and chekc whether the fuse in the power supply board has blown out or not. If it has blown out, never replace it with same type; befor troublshoot the reason for the blown out for the fuse. There must be some reason for the fuse to blow out. Without rectifying it, if you replace it with a new fuse, it may cause more damage to the set.
The power supply board to your TV will look like this.1_10_2012_4_00_19_am.jpg
Jan 09, 2012 | iLO LCT32HA36 Television
I have a 1993 Acura Ledgend. For some reason my heater does not continue to blow hot air, it does for a few minutes and then begain to blow cold air. It does this often now. It works and then it blows cold...
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Nov 30, 2009 | 1993 Acura Legend
Blows 15amp ecm fuse
replace ignition switch
May 29, 2009 | 2005 Toyota Corolla
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
JVC projection screen with blowen fuse
You have to check the reason , why the fuse blew. It is something else that made the first fuse blow. The fuse has nothing to do with picture after the TV starts up.
Dec 02, 2008 | JVC AV-36260 TV
TV Won't Stay On...
I had a service some out and they replaced the amps and the TV has worked fine since then....
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
JVC AV-36260 TV Problem TV won't turn on
  • blowing fuse is a short circuit problem in your tv.
  • please do not replace fuse unless you know the reason otherwise it may damage tv.
  • fuse blowing is due to
  • main filter capacitor
  • power output transistor sort or regulator short circuit.
  • good luck
Oct 21, 2007 | JVC AV-36260 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
