Question about Kitchen Appliances - Others
Find hidden profiles from kallitah83 - Kitchen Appliances - Others
Can you have a hidden profile on my Microsoft surface 2 if so how can I locate it?
Control Panel. Accounts will show all accounts on the machine.
25591863-qztzwsd5tae24twsq5kxbvm0-5-0.jpg Typing lusrmgr.msc at the run prompt will reveal the systems administrators account panel which gives you access to users and groups.
User profiles are available from the System properties panel.
25591863-qztzwsd5tae24twsq5kxbvm0-3-0.jpg In here you can identify or delete user profiles.
Mar 19, 2015 | Microsoft Surface Pro
Tip
How to reset opera back to factory default setting (Profile reset)
The basic steps are 1)Backup necessary files 2)Delete opera6(configuration settings) file from profile directory. See details below.
What is profile reset?
Profile reset removes all your preference settings(like the options you choose in tools>preferences,custom toolbars,menu etc) and let opera rebuild it to the factory default condition automatically. The great advantage it brings that it destroys bad settings that you might have done or might have accumulated with multiple upgrade etc. This is very likely to resolve many issues users encountered with opera user settings.
What to do before profile reset? Do I need to backup?
You need to backup your files so that you can get back your data.
How to do the profile reset?
Close opera. You need to locate your profile directory (Help>about opera will show you the exact location). In windows xp, it is commonly at c:\documents&settings>username>application data>opera>opera>profile and in win vista its under in Win Vista C:\Users\yourname\AppData\Roaming\Opera. Note that "Application data" is a hidden folder in windows and you need to enable the opton to view hidden files and folders(open my computer>tools>folder options>view>show hidden files and folders). Once you have found the folder, just find and delete the file opera6.ini(configuration settings). Restart opera and opera will rebuild the profile settings.
on Nov 19, 2013 | Opera Software Browser
Tip
Create a Hidden User Account This tweak allows an account that is...
Create a Hidden User Account This tweak allows an account that is normally displayed on the Welcome screen to be hidden from view. To log on using the account it's necessary to use the Log On To Windows dialog box similar to the one in Windows 2000 i.e. press CTRL+ALT+DEL twice.
[Start] [Run] [Regedit]
Go to: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\SpecialAccounts\UserList
Modify/Create DWORD Value of Data type REG_DWORD Named [Type Name of Account to be Hidden]
Setting for Value Data: [0 = Account is Hidden / 1 = Enabled]
Exit Registry / Reboot
While the account is hidden on the Welcome screen, note that the account profile will be visible in C:\Documents and Settings or wherever user profiles are stored as well as in Local Users and Groups.
on Jan 26, 2010 | Computers & Internet
I lost my outlook contacts
if there was a probledm with your login profile then you can retrive data from old profile from below location
C:\Documents and Settings\\Local Settings\Application Data\Microsoft\Outlook\Outlook.pst
is thae user name with you log in
Local settings folder might be hidden . you can access the hiden fodlers by checking show hidden files & folders fro windows explorer > Tools > folder Option > View tab > show hidden files and folders
Jun 03, 2011 | Computers & Internet
Someone has made a profile using my name and post a message that breaches confientiallity what can i do
Report the account for "Pretending to be someone else or is fake" The "Report" button is in the bottom left corner of the profile. Example: (Names/Profile Pictures and Profile ID have been hidden)dda10.gif
May 27, 2011 | Facebook Social Network
Have a GE Profile Microwave Oven Model JE1540. the door switch has worn. How do you replace the door switch? Thanks
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
Jan 17, 2011 | GE Profile Spacemaker JVM1871 Microwave...
I can't get the game to work. I get to the profile
Try starting the game with Safe Mode icon located here by default:
Take2->Hidden And Dangerous Deluxe->Play Hidden and Dangerous Deluxe (Safe mode) icon
Nov 29, 2009 | Take 2 Interactive Hidden & Dangerous...
I am using my daughter's old phone, a blackberry curve. She has customized it and I can't find the profiles icon. I need to get out of vibrate and put on a ringtone
The profile icon might be "hidden", if so, press the "menu" key on the BlackBerry then chose "Show all", this will show all the hidden icons.
If not, try to go to "options", then "profile". If that is not there...
Try to reset the BlackBerry by taking the battery out...
If that doesn't work then you need to reload the OS on the BB... (hopefuly you won't need to go this far)
Nov 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Missing "profiles" icon on my BB 8310 curve
In the main screen, before you enter the menu, if you scroll the joystick to the up, you reach the upper profile icon. But to get your old icon back, maybe it's been hidden and you only need to go to your main menu, press the menu button again, and you should see the "Show All" option, if it's selected you can unselect it then you can go back to main menu and you'll see the hidden icons in grey color. When you come over the hidden icons and press menu button, you can select to hide or show them. And when you do the "Show All" steps again and select it again, this time you'll hide your icons selected as hidden.
Apr 15, 2009 | AT&T Blackberry Curve 8300 Smartphone
Windows XP - 'My Documents" missing!
In windows xp there could be multiple profiles.
Check under c:\documents and settings\
Everything in that folder is a user profile. some are system profiles like "all users", "default user", "Network Service" All the other profiles should be user profiles. In each user profile there is a my documents or a user's documents folder.
You should check there to see if you can find your files.
Mar 22, 2009 | Microsoft Windows XP Home Edition
Kitchen Appliances - Others Logo
705 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
