Question about Pioneer DJM-700 Standard Mid-Range Professional Digital DJ Mixer, DJM700,DJM-700-S,DJM-700S
Am getting electric shocks why?
2 Pioneer CDJ350s connected into rear panel of mixer plus an amplifier also connected in rear panel.
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: I want to connect an ipod to pioneer A109 amplifier
go to radio shack near you and buy an audio adapter
number(12-2057).
connect the small plug to the ipod and the others two ends to amp line in or aux in.
Posted on Jan 20, 2009
djmaximus_87
  • 26 Answers
SOURCE: What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Posted on Jun 10, 2009
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
I have shure 101 console audio ..how can i connect to power speaker
this is the manual for your mixer. see page 2 for the rear panel diagram. on the rear panel diagram 24-27 are all outputs, you can run them directly to powered speakers, or thru an equalizer to powered speakers or thru power amps to passive speakers.
outputs 24 and 25 are both the right channel outputs, and 26/27, lkeft channel outputs. the reason each channel has 2 outputs is to support either 1/4 inch or trs connectors
http://cdn.shure.com/user_guide/upload/1597/us_pro_sr101_ug.pdf
Dec 31, 2014 | Car Audio & Video
How to connect 5810 with Pioneer A-20-K Amplifier
Impossible because there isn't MIC IN on the amplifier.You may use small mixer to connect the mic.there and connect the mixer in AUX IN on Your amplifier
Mar 08, 2013 | TOA WT5810-16 Channel Space Diversity...
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Can i connect 2 amps on djm 3000? If yes how?
    I currently have 3 amps connected to one mixer. All you need is to check where your amp is currently plugged into the mixer. now get yourself 2x RCA two way splitters at your local music shop (ie. One male to 2 female)split the channels from your mixer input, and an extra amp can be plugged into the spare plugs
    Apr 14, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
    Pioneer DEH-P6400MP plus a Jeep Infinity Gold 2 ohm system
    yes but make sure you connect the power wire of the amplifier and buy a converter for the amplifier so you can get great sound.
    Sep 20, 2009 | Pioneer DEH-P4600 CD Player
    Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
    Pioneer djm 800 will only play through 2 channels on mono??
    try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
    Apr 11, 2009 | Audio Players & Recorders
    Electrical problem no rear lights or dasboard lights
    check out the electrical wiring once and the power connections.As your car is slightly old, the wires may have weared of....
    Nov 17, 2007 | Pioneer GM-X962 Car Audio Amplifier
    Wiring Diagram for Sony car amplifier XM-554ZR
    You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
    Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
    Pioneer DJM-700 Standard Mid-Range Professional Digital DJ Mixer, DJM700,DJM-700-S,DJM-700S Logo
    130 people viewed this question
    Top Pioneer Electronics - Others Experts
    Steve F
    Are you a Pioneer Electronics - Other Expert? Answer questions, earn points and help others
