Question about Toshiba E-studio 281c Copier
My copier does not give clear copies whether you increase the density? what can i do
  • 79 Answers
Replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Posted on Apr 05, 2015
What can i do for toshiba 281c if it not giving clear copies?
replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Apr 04, 2015 | Toshiba E-studio 281c Copier
Getting light print on b&w, changing density makes zero change. Toner changed, no effect.
Check whether you are running as Black and White or Gray Scale. Many printers only print straight black by using all four toner cartridges- Cyan, Magenta, Yellow, black. If are running colored print in black and white and u choose grey scale it will automatically give you a screened image as a light print.
Mar 27, 2015 | Office Equipment & Supplies
Increase the toner density toshiba copier e-studio 16
clean scanner drum unit change with good toner.
Sep 10, 2013 | Toshiba e-STUDIO 16 Printer
NEED DARK COPIES
please increase the density of the copy.
Aug 23, 2013 | Gestetner DSm635 Copier
Even after replacing the toner cartridge the toner light remains on and the copier will not operate. I have tried agitating the cartridge with no effect. Occasionally on switching on it will operate for a...
Hi Paul
Please answer me a few questions and Ill look into your issue when I get some time later today
Are you using Sharp original toner or after market?
Is the light the "billard ball" one and is it on solid or blinking
Is the drum light on also?
What is the page count on this machine
"clear, density select, clear, density select, dilpay blinks 00 then use arrows for up, zoom for down, to put in 22, press copy then arrow in 05, press copy.. result will be 3x 2 digits repeaed, clear to exit to start of service mode
what is the drum count?, same as above but 12 instead of 05 for second lot of entry
TRy doing clear density, clear density, then 10 copy, can you hear toner motor turning for 30secs?
Dont play in service mode you can damage machine if wrong stuff is put in;)
(clear then clear again to exit all the way out of service mode)
Please post back results/answers
Cheers
Soulvisitor
Oct 10, 2011 | Sharp AL-1217 Copier
Minolta bizhub 222 dark copies
Whenever you ask about any problem please explain in detail.There are couple of reasons behind the above mentioned problem.Its not clear that copies are all black (full black) or just dark in print density? or its giving a dark shade? As per asked question, the solution is Check the followings1-Scanner mirrors are dirty2-Drum is damaged or faulty3-Charging corona 4-LD unit5-Developer
Aug 19, 2011 | Konica Minolta Bizhub 222 Black and White...
Sir, I am having IR400, the copy became white coloured font with very dark black background, so i replaced drum & blade and then copies became normal, but very light, then i increase the density from 5...
Why did you do ccd-adj before cleaning the optics?
in copiers front door must be sheet with numbers that are factory input, do the clear all, and then set the values from paper in service mode.
May 18, 2010 | Canon imageRUNNER 400S Copier
Al1644
After you hit clear, density select, clear, density select, the lights showing number of copies selected should go out, they they go out, you are in the Simulation (Service) Mode. Then select 14 and hit the Start Key. You may have to re-enter the Sim. Mode then enter 15 etc.
Aug 11, 2009 | Sharp AL 1631 Copier
Hi tohisba e studio 150
This is a fuser error.
First you must enter the simulation mode as follows:
press the keys clear, density select, clear, density select
then press the copy key
use the arrow up and down buttons to select the number 14 in the display
press the copy key
this should fix the problem
c
Aug 06, 2008 | Toshiba e-Studio150 Copier
Toshiba E-studio 281c Copier Logo
52 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
