Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Motorola SB5101 I have two PCs (XP) connected to SB5101 via ST Lab Switch Hub. One PC is successfully accessing internet while the other PC reports 'limited or no connectivity'. I have even replaced the network card in this PC to no avail. Any tips appreciated. Cheers, Lacan.
  • Anonymous Nov 28, 2007
    Yes, I have a Motorola SB 5100 with an Ethernet connection to my PC.
    I now wish to also run a Mac Laptop via a Mac Airport Express wirless unit (which they tell me has an inbuilt router, I was also once told that the SB5100 has an internal router, but now doubt it). I have run the ethernet cable from the SB5100 to a Wiretek Fast Ethernet switching hub with a line out to my PC and one out to the Airport Express unit. My PC works fine, but no the Mac.
    Have I set this up correctly, or do I still need another router.
    Thanks
    Scholar:
  • 193 Answers
Ya u should have a router instead of a modem because modem provide only one ip address>and there is no DHCP server in the switch or hub>so buy one router which has 4 ether net port and connect it directly to the modem and connect ur two pc's behind the router then both will get a seperate ip address from the router both will go online
the connection is
modem-->ether net cable to the inter net port on the router-->and two ether net cable from both pc's to the 1 and 2 ether net jack on the router reboot all the devices>and modem+router+pc's then it will work>rate me solved if its helps thx
Posted on Nov 14, 2007
  • ramji duraiswamy Nov 14, 2007
    what happend have u tried
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
I cant get my motorola sb5101 surf board cable modem to connect to a belkin g wireless router. the light on the belkin flashes orange when i try to connect it to the modem but no internet connection
I have a similar problem. The common denominator seems to be the SB5101. I have a brand new Belkin Surf 300N, same issue. The modem will not give DHCP to the router. I can connect fine via ethernet to the modem directly.
This modem seems to be a dinosaur.
May 21, 2010 | Arris SURFboard SB5101 Cable Modem
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
My Motorola Sb5101 modem will not let me access the internet, the send light constantly flashes and i can't attain any internet connection.
If you have the following lights :
Power light - on
Receive light - flashing
Send light - flashing
Online light - off
PC/Activity - on
Standby - off
Then your Network Access is OFF - modem is successfuly registered but Network Access Control is disabled via DOCSIS configuration file.
Call your internet service provider....
Nov 06, 2009 | Arris SURFboard SB5101 Cable Modem
Can't acces internet by using Motorola SB5101
You need to input IP and DNS information in windows. I can only help you where to input but you need to contact your ISP for IP address.
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Connecting 2 PCs Via the D-Link Hub
Hi Ajog,
Those Ips look good. Make sure the Subnet on both is 255.255.255.0. Since they are both getting to the internet, I assume the Gateway IP is correct.
On the 192.168.1.3, got to Start>Run and type in CMD. A black window will open, and type in PING 192.168.1.65. You should get four responses. If you don't, you probley have a firewall issue.
Do that same on the 192.168.1.65 machine, back to the 192.168.1.3 machine.
On the XP machine, follow these instruction, just skip down to Step 9.
http://www.geekgirls.com/windowsxp_home_network.htm
Vista gets a little tricker, but not bad. To setup the network on the Vista machine, go here, ad click on the Network icon.
Great link to save to your desktop!
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
Using the network wizards should setup your firewalls to allow File and Printer Sharing.
Good luck
Jan 08, 2008 | D-Link DE 805TP/C (DE-805TP/C) Networking...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
548 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
