Question about Building Materials
How do I revert back to my original signal after putting in a KLICK2U, which I am now removing because non of my original openers work?
  • Rich
    Rich Apr 06, 2015
    I caI called Chamberlain and they walked me through the process of getting all to work fine.
    Top Expert:
  • 12,962 Answers
U have to reprogram the door opener to work with whatever remote device you wish to use. The device will come with the instructions for the various door openers.
Posted on Apr 06, 2015
Uv-5ra programming
The problem I found with the programming software was with the driver that is included with the software. Google Baofeng software driver and follow the instructions on how to load as well as how to remove the non-working driver. If you don't remove the original driver, windows will revert back to the original instead of using the new driver. Good Luck!
Jan 15, 2014 | Dual Uv-5r Baofeng Feq Uhf/vhf Radio Free...
My dvr 16sb started producing a dreadful signal now after buying new cables etc and re installing the channels I have no signal at all. I have reverted back to my old cables and back again but still...
Go back and do ONE channel. disconnect everything else and just try hooking up ONE channel. when you find what you may have done wrong, then fix them all. A Bad Camera Power supply will cause your original issue,
Oct 26, 2013 | Televison & Video
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
With the new battery (non original) I brought my keypad locks up and I have to put my old one back in again before I can press anything on my keypad. Why would a battery affect usage? Geoff
non original battery might vary the output voltage and in turn it will affect the normal working of the PDA, so it is advised to use only original battery.
Jan 08, 2011 | Computers & Internet
PS3 turns on but I don't have a picture. It acts like it is not hooked up but it is.
A common problem is that the video signal is sometimes sent out in a non standard format. If you try holding down the power button for 5 seconds it will revert back to standard definition and hopefully you will get a picture.
Aug 06, 2010 | Sony Playstation 3 (PS3) Console
Replaced batteries on klick2u garage door opener. Having trouble reprogramming with 2000 liftmaster garage door opener
You will need to match the 10 dip switches inside the transmitter to the 10 on the motor head. That is is. Thanks BB
Jan 02, 2010 | liftmaster Chamberlain Garage Door Opener...
2002 Hyundai elantra driver side turn signal not working outside
This simply means that the front driver side turn signal bulb has failed. Replace it.
Oct 28, 2009 | 2000 Nissan Maxima
Optiplex G620 has "munged" BIOS Admin password. Children plaed and saved. Any idea how to clear it ?
Hi there.
Try clearing the cmos fdbf23f.jpg. move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, password should be removed.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Dell OptiPlex GX620 PC Desktop
Acer laptop vista home basic
Easiest solution is to reinstall Vista.
You may be able to do this without losing your data (Do a Rpair rather than an Install) but I suspect that this will not remove the password.
I have not done what I am about to describe with Vista so I am not sure if this is even an option, but you may be asked to create User Accounts when repairing Vista (same as when doing an Install) - if this is the case you could create a new account and give it Administrator rights. When you restart the computer - enter as the Administrator and change the Attributes of the original account (remove the password). As I said, I don't know if this is an option with Vista.
Note: I have just uninstalled Vista for the second time (reverting back to XP), I may give Vista a go again when SP2 or SP3 comes out and then again I may not. So my knowledge and ability to experiment with Vista is now non limited or non existant.
Good luck.
Apr 13, 2008 | Microsoft Windows XP Professional With...
Building Materials Logo
61 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
