Question about Building Materials
Klik2u model won't learn from the handheld opener and when I press the learn button my other remotes are inactivated and vice-versa. How can I program the klik2u w/o losingcodes on handheld r
    New Friend:
  • 130 Answers
Try erasing all of the codes in your opener. Then try reprograming your remotes and etc. Openers will only accept so many codes. After they reach their max they will accept a code then boot another one out.
Posted on Apr 05, 2015
My remote sends a signal, the opener indicator flashes, but the door does not open?
The learn button is located on the garage door opener unit itself that hangs from the ceiling. If you follow the gray antenna up to the unit you will see a red/orange button on the unit. That is the learn button. When you push that button and amber LED will light up either above or next to the learn button. This indicates that the garage door opener is now ready to learn a new device. Press and hold the button you want programed on the garage door opener remote and release it. The garage door opener will click and the garage door opener light will go off and come back on (if the light bulbs are in working order). The amber LED will go out, repeat if you need to program anything else.
Feb 22, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
How do I check a wireless garage door keypad, to see if it is transmitting?
These remotes don't loose the programming code when a battery goes dead, most likely the remote or the board on the opener went bad, do any other remotes work? You can take the remote to an auto parts store and test it there. (They have a tester for key fobs)
Sep 24, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
Help, our neighbors can open our garage door with their remote, but not vice versa. Want to reset the code on the garage door motor, but have no manual...thank you for any help!
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Jan 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Help w/ programing keypaqd along w/remotes
I press the learn button on the door motor. I wait a few seconds and press a new 4 digit code into the keypad, hold down on the "enter" button for several seconds so it learns the code. Now the remote will not work. Press the learn button again, press the button on the car remote until the light on the motor blinks. Both should work after that.
I have Sears LiftMaster products. Hope that helps.
Jul 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
194 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
