Question about Refrigerators
Why does the ice maker freeze up?
If I turn on the ice maker, ice forms inside the freezer and the ice maker freezes up. Water drips onto the next shelf and ice is not dispensed as the ice chute freezes.
  • Refrigerators Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Posted on Apr 10, 2015
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Ice maker filling with water but not freezing into cubes.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
