Question about Dehumidifiers
The warning light is flashing and the dehumidifier won't work. Any advice x
  • 2,760 Answers
Empty the water collection bucket ??
or if it was just empty'd then reseat the collection bucket its not far enough in
Posted on Apr 15, 2015
2 Suggested Answers
  • 4736 Answers
SOURCE: power light flashing on danby
As I tell most folks who complain about the problem you're having
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter. To remove the filter on your model it will either have a pullout tab on
the right side of the unit, behind the louvers on the front. Or remove the bucket and the filter
frame will be just on the inside top of the opening behind the front louvers.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
in basement applications level. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Posted on Jun 25, 2011
Our dehumidifier seems to be working fine but the orange light is flashing above the star mark
When an error occurs, the Alarm lamp flashes orange. Check the status of the lamps, then take the appropriate action in Alarm Lamp Flashes or ON Lamp and Alarm Lamp Flash Alternately.
Jan 10, 2017 | Dehumidifiers
Electrolux EXD15DN3W dehumidifier has power to unit, but wont start operation? Display is off, on button doesnt respond, but LEDs light and beeps when bucket is removed. Any advice much appreciated.
The bucket interlock may be defective. It works correctly to signal when the bucket is removed but doesn't signal the power switch that the bucket is in place.
Nov 23, 2016 | Dehumidifiers
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
Beeping tank warning light blinking, pump light not on
I think this means your pump is not working, and therefore the tank is full. The pump could just be switched off, could have failed, or could be clogged. See the other messages regarding this model, for an excellent description of how to clean out a clogged pump.
Oct 02, 2014 | DeLonghi DE500 Dehumidifier
Bucket full light flashes, humidity setting won't change - only says 01
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Jun 07, 2011 | LG LHD459EL Dehumidifier
Kenmore 580-54701500 is not working. I noticed a burning smell before it quit. Light comes on control panel- but pressing buttons does nothing. maybe a fan or motor needs to be replaced. not sure if...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 21, 2011 | Kenmore 54701 Dehumidifier
Dehumidifier on but not working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 25, 2009 | Daewoo DHC-400 Dehumidifier
Auto-off light keeps flashing
I have the same issue.  Any responses?
Jul 03, 2008 | Kenmore 54351 Dehumidifier
Dehumidifiers Logo
247 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
