Question about Whirlpool Washing Machines
Whirlpool Front-Load Commercial Washer how to reset computer after I replaced the pump for F21 code
CHW9900VQO
  • Whirlpool Master
  • 473 Answers
Usually if you unplug the machine for 5 minutes and then plug it back in that will reset error codes.
Posted on Apr 05, 2015
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What are the codes for a front load whirlpool washer F21
Hi
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F21 code
try doing the following :
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Our washer has been displaying the codes F21 and
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 24, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
