Question about Ricoh Aficio 1515MF All-In-One Laser Printer
How can i go into service mode?
I have a problem to enter the system setting where i lost the operator code key , i asked how to reset or remove the the operator code key and the answer was ( To clear key op code go into service mode then 7 then 810 will reset it ). But my question now is how can i go into service mode?)
  • Ricoh Expert
  • 155 Answers
Press clear mode then press 1 then press0 then press 7 then press stop button hold down for 5 seconds should see display say 1copy press 1 then press 7 ok then press 810 press ok follow instructions.
Posted on Apr 06, 2015
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
How can i go into service mode?Please i need the answer supported with pictures.
Hi there! As you have to understand, i (WE..) are subject to some secrecy about codes...
its not because we enjoy it but , hey, we are dealing with juice.
If all people has access to codes, 4 me its ok! NOTHING to worry about!
Its what you make of them if you dont have a clue what you are dealing with...
You wanna be the nice guy who solve a problem but you run away the net if you f** *** a bad situation
so.. Heres is the access to service mode. But please, and this stand to ALL rookies, this is always goes in your responsibility, so be gentlly.Yellow button, 1, 0,7, and stop (red button)keep this button pressed by 3/4 seconds...
YOU WILL SEE ACCESS TO TECH MODE.WHAT YOU WILL DO FOR NOW ON ITS IN YOUR INTIRE RESPONSIBILITY!
I HAVE BEEN WORKING with ricoh and all machines related ( Rex Rotary, Nashuatec,Etc etc , and also Minolta, Toshiba,Canon, etc , you name it,ive seen them all,... and its about 30 years... but after all, as a tech man, i have to render to a status! Y ou have to had a training course, a problem or two,who made you familior with the machine, and so on ( Is 30 years!!!) and then you play with solutions.4get about newcomers, going to tech manuals and give you the answers already writen there...30 years working on this dont make me an expert, but..advising you not to take the short way...im serious!
I Really enjoy Fixya! And, sometimes,i come here to get a second oppinion, when there is a doubt.so........
Apr 07, 2015 | Ricoh Aficio 1515MF All-In-One Laser...
HOW REMOVE IT FROM THIS Defective power supply ERROR
Reset C6400 ERROR
turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Select Service setting using
the up/down cursor keys.
While pressing the start key and the # key,
press the enter key..........Maintenance mode is entered.
Select Maintenance mode using
Press the enter key.
Enter the maintenance item
number U163 using the up/down keys.
Select Execute using the up/down cursor keys.
Press the enter key. The fusing problem data is initialized.
Apr 15, 2014 | Kyocera FS-1118MFP Laser Printer
Resettare errore c6
1-4-1 Maintenance mode
The machine is equipped with a maintenance function which can be used to maintain and service the machine.
(1) Executing a maintenance item
The selected maintenance item is run.
Press the back key.
Start
End
The maintenance item is
selected.
Maintenance mode is exited.
Repeat the same
maintenance item?
Run another maintenance
item?
Turning power switch off and back on
No
No
Yes
Yes
number using the up/down keys.
Press the system menu/counter key.
* The test print mode cannot be stopped until the preset number of sheets is printed. To stop the operation, remove the
cassette to cause a paper empty state. To terminate the test print mode in the middle of operation, you must turn off the
power switch and then on again to exit the maintenanc
when in maintenance mode go to 163 to reset
Mar 16, 2014 | Kyocera FS-1118 Printer
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
I HAVE A SAMSUNG CRICKET SLIDER SCH R 450 AND I CAN NOT GET IT OUT OF SILENT MODE ACTIVATED I TRIED ALL SETTINGS AND EVEN REMOVED BATTERY I AM FRUSTRATED THANKS PAT
Consult your users' manual that came with the phone. Look for information regarding a "Master Reset". Any information *not* stored on your SIM card or in other card memory WILL BE RESET and LOST. This includes any settings you may have made to include the mistaken setting of silent mode.
If asked for a master reset pass-code, common Cricket/Nokia codes read like luggage combinations...
Try "0000" or "1234".
If it asks for a 5 digit, put in 12345.
If it asks for a PUC, call Cricket 1-800 service hot-line from LANDLINE with the cell phone in hand and operating properly.
Make sure that your battery is fully charged before starting the master reset sequence! Good luck. :D
May 09, 2010 | Samsung Cell Phones
Hi, We have a second hand mp 7500 copier in our office and some idiot blocked the pin entry on it. Is there a default or reset code available to override the pin system? Please help, i have no manual for...
Enter in the user tools.Enter SP mode then enable the user code mode by selecting SET.Turn OFF the power switch.Remove the plastic cap on the right upper cover.Conect the key counter shortcircuit connector and turn ON the main switch.Reset the user code and turn OFF the machine and disconnect the shortcircuit connector.Turn ON the main switch and check the operation.
Oct 06, 2009 | Ricoh Aficio MP1600SPF Copier
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
117 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
