Question about Welding Tools
My Ranger 10000 plus dies when switched to auto idle setting and will not stop running when switch is turned to STOP position.
Worked fine last time I welded. Have cleaned the terminals on the switch.
2 Suggested Answers
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
I have a Ford 1990 f250 xlt 7.5 When starting revs up and down slowly then dies sometimes, why?
Clean the throttle body and idle air control motor(IAC) on the side of it. Mostly the IAC and the hole it sets in. Also check the air filter.
Apr 26, 2015 | 1990 Ford F250
When idleing at a complete stop it dies
Check air cleaner. put some Lucas injector cleaner in the gas tank or a product called mystery oil. Also at night with all the lights off open the hood and watch to see if their is any sparking between spark plug wires.
Feb 23, 2013 | 1999 Ford Ranger SuperCab
1990 Buick Park Avenue heat works intermittently
check connector at blower motor, common problem there.
Dec 12, 2009 | 1990 Buick Electra
I have a 1994 buick lesabre, it idles fine however when you drive it and come to a stop sign it either tries to cut off or dose cut off, pressing the gas pedal dose nothing at all, some times it will try...
If t dies hard - feeling like the trani is not disigaging when you stop - it could be a electronic part inside the trani.. This part tells the stall converter to kick in at a stop.. Not super expensive to fix.. But best done by a trani shop....
Jul 08, 2009 | 1994 Buick LeSabre
1990 Ford Ranger Stalling
if it were me I would start with the idle air controll sensor, this is a real humdinger on fords. also clean out your throtle body really good.
let me know
tepfy
Apr 22, 2009 | 1990 Ford Ranger SuperCab
Wipers do not work in intermittent position. They do work in low and high speeds but do not automatically return to the park position. They stop wherever you turn the switch off.
i belive that your wiper switch has gone out on the intermittent side. this is a very common problem.
I hope this helps you
Thanks
Please leave rating
Apr 21, 2009 | 2000 Isuzu Amigo
Heater does not work. Truck dies at stops
As far as heat goes I would replace your Thermostat and that should stop it from blowing cold due to the fact its probably stuck open unless your heater switcher arnt switching from vent to heat when you turn them. Does your temp gauge show your truck is running cooler then it use too? As far as it dying when you come to a stop that might be a few things I would check idle screw first then plugs clean or replace then Go to throttle position sensor (TPS) or AIR TEMPERATURE SENSORS (IAT) sensor. They somtimes wont turn your service engine light on but still will cause problems if they need cleaned.
Mar 09, 2009 | 2003 Dodge Durango
Auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Dec 09, 2008 | Honda 6370C - Parallel Power Kit For ...
Welding Tools Logo
104 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
