Question about Welding Tools
I own a ranger 10000 plus. It will not idle down when set in to auto idle mode and it will not shut off when the switch is set to stop. Bad switch or something else?
It worked fine the last time I welded with it. I have cleaned the terminals on the switch.
2 Suggested Answers
  • 5 Answers
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
Posted on May 03, 2009
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
How do i adjust idle speed 1992 ranger v6 auto 4x4
it's probably the auto. choke out of adjustment. there's no idle adjustment on mine .i guess u could bend stop or something??
Nov 29, 2011 | 1992 Ford Ranger
Our hydrovane 711s doesnt shut down when up to presure on auto mode &lt; constaint not a problem when auto still like nothing has changed
The unit probably has modulation cpability, meaning that it can throttle the inlet valve to match demand, sort of like cruise control for air pressure. If it is modulating at a lower pressure than the idle/shutdown pressure, then it will never shut off, even in auto.
If it unloads, but never shuts down, you might have a bad timer in the control panel.
Mar 12, 2011 | Electric Air Tools & Compressors
How often should plugs and wires be replaced
Plugs every 30000 miles and plug wires at 10000 miles unless you have misfire problems. Spray the wires with a water bottle and fine spray while the vehicle is running. If you have a bad wire you will get a misfire and rough idle.
Oct 08, 2010 | 1989 Ford Ranger
Dome light stays on even with door shut how to fix?
adjust he pin in the door tothe right setting
Jun 15, 2010 | 1998 Ford Ranger SuperCab
I have a 98 ford ranger poping sound
control arm bushings that are worn do make that noise
Down load a service manual for your vehicle from this website
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 02, 2010 | 1998 Ford Ranger SuperCab
Unit starts with auto throttle off. engaging auto throttle shuts down unit. in past months, pluging in a cord would shut down unit. That is with no tool in use, just plugging into the receptacle.
Hi. There are 2 things that control the Auto Throttle and that is the idle control valve (Connected with black and yellow wires) and the Auto Throttle Unit.
Start Generator
Check for 12VDC on the Yellow wire of the idle control valve. Yellow is positive to any good Chassis ground. If you don't have 12VDC then either the Auto Throttle switch is bad or the Auto Throttle Unit iself.
You can gain access to the Auto throttle switch and again check for 12VDC to Ground on both sides of the switch with the switch on. (It may read as high as 13.8 engine running) If you don't get 12 - 13.8 VDC the the Auto throttle control unit is bad
If you have 12VDC to the Idle control Valve and it does not work perform a resistance check across the coil of the Idle control Valve (both wires disconnected Engine off) Black to yellow should read 3 to 4 Ohms If you have no resistance then the coil in the Idle control Valve is bad.
If you need more help just respond here
Kelly
Feb 09, 2010 | Honda 3000 Watt Portable Generator
My ford ranger 2004 v6 engine stopped and now it almost start but shut down again imediatly, what can be wrong ?
Fuel shutoff switch located by passenger right foot kick panel. remove cover and reset switch. Come problem with rangers. Switch gets weak and passenger kicks panel and truck shuts fuel off.
Sep 09, 2009 | 2004 Ford Ranger
Auto high idle lincoln ranger 8
Apr 29, 2009 | Lincoln X2688 2 YR EXTENDED WARRANTY FOR...
Auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Dec 09, 2008 | Honda 6370C - Parallel Power Kit For ...
Welding Tools Logo
142 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
