Question about Garden
The recoil starter will not operate. If I take the spark plug out it pulls fine
  • 2,760 Answers
This saw obviously has a compression exhaust problem(stuck reed valve?) , id look carefully at muffler first then id try taking spark plug out and filling piston (thru same hole) up with plain auto transmission fluid not synthetic oil (its got a rust dissolver in it ) leaving it overnight , draining that out completely and reinstalling the plug , trying to pull over with cord , if this does not work engine will need to be disassembled to discover other cause
Posted on Jul 24, 2015
dontbother10
  • 2220 Answers
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Posted on Sep 17, 2009
Testimonial: "cheers"
dontbother10
  • 2220 Answers
SOURCE: Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 27, 2010
  • 4088 Answers
SOURCE: Poulan Wildthing pull starter problem hard pull;
Many modern saws have sufficient compression to present difficult pulling of the starter cord. Suggest trading in for a saw with a compression release. The only repairable problem with the present saw is if it is flooding the engine and you are trying to compress liquid fuel. You can tell by removing the spark plug and pulling the starter through forcefully--it will blow out raw fuel if it is flooded. Change the diaphragm in the lower carburetor chamber if it is flooded. Hope some of this helps!
Posted on Jul 03, 2010
  • 2428 Answers
SOURCE: i have the toro ccr
You have to understand its a cord spulled around a recoil spring. The coed likely didn't rewind correctly one time. However the entire unit unbolts with three screws.Remove the unit from the engine and check the cord and realine the core raping path as well as check the return recoil spring function. If you can not realign you can replace the unit as a part. After the first pull the engine has pressure to and that makes it harder to pull to.But try re alinging the assembly i have to do it to mine and its a 1964 and it still works
Posted on Dec 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Can't pull the starter cord,
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Posted on May 15, 2011
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
Tip
Another ways to check the engine compression
Remove the spark plug and ground the plug wire on the engine.Seal off the spark plug hole with your thumb.Operate the starter.If the compression pressure blows your thumb of the hole,the compression is adequate for the engine to run.
With the spark plug in place remove the cooling shroud/recoil starter mechanism and spin the flywheel counterclockwise.The flywheel should change direction sharply,if so the compression is adequate for the engine to run.
on Dec 19, 2009 | Garden
Pulled starter rope, it's now stuck and won't recoil
Cool!
A Project.
Remove the spark plug lead just so you can't have it accidently fire.
Remove engine cowlings as necessary to get at recoil starter.
Remove recoil starter (that's the bit that the pull rope is attached to.
Dis-mantle it until you can find what is wrong. Fix or replace.
Put it all back together.
or
Take it to a small engine repair shop and pay a bunch.
Mar 06, 2016 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Toro snowblower troubleshooting
FOLLOW this steps and fix it. Merry Christmas
Spark Plug
Every chainsaw relies on a spark plug to ignite the air-fuel mixture for proper combustion. Over time the electrode on the spark plug will burn away and the engine does not start. If the engine does not start, remove and inspect the spark plug. If there is any doubt that the plug is working properly replace it.
Enter your model number to see parts for your chainsaw.
Carburetor
If the chainsaw won't start, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the chainsaw for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn making it hard to start the engine. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
On - Off Switch
Chainsaws are equipped with an on/off switch. If the chainsaw does not start, this switch might be defective. Check the switch for continuity. In the on position the switch should have continuity.
Safety Switch
If the chainsaw does no start, the safety switch - or throttle control switch - might be defective. If the switch isn't engaging with the throttle it won't provide enough fuel to the engine and the engine does not start.
Ignition Coil
If the chainsaw engine does not start the spark plug may not be getting voltage. Power to the spark plug is provided by the ignition coil. The ignition coil is mounted next to the flywheel. As the flywheel spins an electrical current is induced by the ignition coil. If the ignition coil is defective it will need to be replaced, it is not serviceable.
Rewind Spring
The recoil starter assembly has a rewind spring which spins the pulley backward to rewind the starter rope. If the rewind assembly is broken the rope will not rewind and the engine does not start.
Recoil Starter
If pulling the recoil starter assembly handle doesn't engage with the engine and the engine does not start. Repair or replace the recoil starter assembly.
Recoil Starter Pulley
The recoil starter pulley winds up the starter rope when not in use. If the recoil starter pulley is broken or stuck it may not rewind the rope and the engine does not start.
Dec 19, 2013 | Toro Garden
Yard Machine Model 21a-121r900 tiller's pull starter recoil pully slipping
Bend the ears on the flywheel so that they are 90degrees. They are not lining up right.
Feb 16, 2013 | Mtd Garden
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
Husqvarna 125r wont start. has spark, compression, air filter and exhust checked. could it be the timing? if so how do you adjust?
Pull spark plug out. Pull cover from recoil starter. Pull recoil starter. Inspect flywheel mag's for cleanliness. Then turn engine over untill piston is topped out. Your manets and pick up should be lined up to eachother at this point. If they are not, pull nut and or bolts from flywheel and remove to check for damaged key-way or woodruff key that aligns flywheel to crank. That is the only timing.
Apr 27, 2010 | Husqvarna 28cc Gas Line Trimmer
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
